Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Karbonn
Old 06-16-2014, 16:23   #31 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
Karbonn Titanium S4 Hard Reset [Available]
1-press vol plus and power button
2-screen will b green do not relese button
3- now screen will b red relese button
4- press vol plus button
5-now go to wipe data press pwr to selection
6 Enjoy
Old 06-29-2014, 11:10   #32 (permalink)
Member: 496386
Thanks Meter: 6
karbonn A 90 partten lock
sir karbonn A 90 partten lock plese help me
Old 08-21-2014, 19:23   #33 (permalink)
Cheater -Don't Deal with him-
Member: 1618492
Sonork: 100.1619678 QQ 2483222717
Thanks Meter: 488
Arrow
Karbonn A52 Hard Reset Procedure
STEP 1 : Hold Volume up + Power button [ you can see the android logo ] in the bottom [ no command ] appear
STEP 2 : Press Power Button [ android system recovery 3e ] Found
STEP 3 : volume Down to move Highlight [ Wipe Data/Factory Reset ] VolumeUp Button to Select
STEP 4 : Select Yes -Delete all User Data [ VolumeUp Button to Select ]
STEP 5 : Reboot System Now
Hard Reset Done
Old 09-03-2014, 07:26   #34 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 303
karbonn a1+ duple hard reset done>>>>100000%
1- press volume up and home and power for 5 to 10 second.
2 -you will see 3 optinon-
select recovery option by volume up key and press volume down to enter
3 - set give you menu for wipe data.
now do as you do always.
if like it ,dont forgate to --------------------?
Old 09-05-2014, 10:41   #35 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
Karbonn A51Lite Hard Reset Solution [Available]
press volume down and power button
its goes in recovery mode then press volume up it shows android menu
now u know what to do.......
sunnyelectronics
The Following 3 Users Say Thank You to sunnyarora For This Useful Post:
Old 10-02-2014, 11:04   #36 (permalink)
MUKESH RAJ's Avatar
Member: 1084080
Thanks Meter: 3,427
Hard Reset Done : Karbonn Sparkle V tested by MUKESH RAJ
1. Press Volume Up and Power Key
2. Now Select Recovery (Pressing Volume Down Key)
3. Press Power key
4. Press Volume Up Key Without Leave Power key
You will See
Recovary Menus
Now Select Wipe Data/Factory Reset
BR,
MUKESH RAJ
The Following 2 Users Say Thank You to MUKESH RAJ For This Useful Post:
Old 11-08-2014, 09:14   #37 (permalink)
Member: 1957025
Sonork: starimmu
Thanks Meter: 2
karbonn a51 plus hard reset
karbonn a51plus hard reset (_vol and power botton) u see karbon logo after u enter recovery mode then select CLEAR FLASH u will be done enjoyyy 100000% done dnt forgot to click thanks
The Following User Says Thank You to shek.ayaz For This Useful Post:
Old 11-26-2014, 12:11   #38 (permalink)
Hifzul Amin's Avatar
Member: 2144988
Sonork: 100.1655364(Offline)
Thanks Meter: 217
Smile Karbonn A1 Pro Hard Reset Solved
Press Vol Down+Power Key Both for 30 Second
After 30 Second Mobile Screen Start up Karbonn logo and hard reset menu is coming
Now Wipe your set easily
Tested Today Before Post
Wbr
Hifzul Amin
The Following User Says Thank You to Hifzul Amin For This Useful Post:
Old 12-29-2014, 11:54   #39 (permalink)
Member: 2288882
Karbonn A55i Hard rset done100%.....
Pres vol down and power key for 20 second, now you see starting page now press vol up see menu list select clear flash your phone is now reset
Old 02-16-2015, 13:39   #40 (permalink)
Member: 1248435
Thanks Meter: 28
Karbonn a108 hard reset done
press vol- and power button together phone shows five options vol down and select rnter recovery
press power to ok now select wipe data factory reset select by on off key and yes delete
all user data
The Following 2 Users Say Thank You to jogichanana For This Useful Post:
Old 03-11-2015, 09:57   #41 (permalink)
Member: 2143664
Thanks Meter: 2
karbonn a109 hardreset
-vol and p/w then select clear flash
100% done
Old 04-27-2015, 10:15   #42 (permalink)
Member: 1715800
Sonork: vinay
Thanks Meter: 4
karbon w4 hard reset
1 trun off phone 2 press the power button once 3 press and hold the volume down button until you see theexclaatiob on the screen 4 release the all button 5 press the followng buttons in excat chonological order 6 press the volume up button once 7 pess the volume down buttne once 8 press the power button once 9 press the volume up buttne once 10 hard reset will start immediately
Old 06-29-2015, 16:24   #43 (permalink)
Member: 2170960
Sonork: 100.1654878
Thanks Meter: 2
video for hard reset sparkle v
here is hard reset video https://www.youtube.com/watch?v=ObxHpCIkLXY
The Following User Says Thank You to neeraj lalwani For This Useful Post:
Old 08-25-2015, 13:49   #44 (permalink)
Member: 1248435
Thanks Meter: 28
Karbonn S202 hard reset
press vol up + power button together screen shows some chinese options
now press vol- button and choice the last option press vol up button
for ok thats all android shows and all user data wipe
The Following User Says Thank You to jogichanana For This Useful Post:
Old 09-06-2015, 13:24   #45 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 643
Karbonn A108 Hard Reset Solution For Pattern Lock.
first vol- and power botton
now select boot mode enter recovery
then select wipe data/factory reset
now ur phone is unlock
The Following 2 Users Say Thank You to sachu2002 For This Useful Post:
Page generated in 0.46349 seconds with 8 queries
