Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 01-02-2013, 16:59   #1 (permalink)
Member: 733869
Thanks Meter: 10
Karbonn a1+ : how to do the pattern lock?
karbonn a1+ pattern lock
how to hard reset....
plz help....
The Following User Says Thank You to bhavinjilka For This Useful Post:
Old 01-02-2013, 19:07   #2 (permalink)
pintu.pattnaik1's Avatar
Member: 1351981
Sonork: 100.1640597
Thanks Meter: 48
vol - key + home+power solved and replay
The Following User Says Thank You to pintu.pattnaik1 For This Useful Post:
Old 01-03-2013, 16:17   #3 (permalink)
Member: 733869
Thanks Meter: 10
not work for me bro...
Old 01-03-2013, 16:34   #4 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
I HAVE ALREADY POSTED JUST SERCH, DONT JUST OPEN THREAD
http://forum.gsmhosting.com/vbb/f606...-mono-1591854/
Old 02-01-2013, 21:41   #5 (permalink)
Member: 963505
Thanks Meter: 50
plz help....
SET START AND JUST ENTER MENU -SETTING-PRIVACY-FACTORY SETTINGS RESET--(PASsWORD- U OR ULTA U
TRY LEFT SIDE OR RIGHT SIDE
100% OK
The Following 2 Users Say Thank You to sonugola2 For This Useful Post:
Old 02-08-2013, 08:49   #6 (permalink)
Member: 325515
Sonork: 100.100.1638136
Thanks Meter: 3
no replay sir plz help me
Last edited by ..::Nokian CareŽ::..; 05-25-2013 at 12:25. Reason: removed mobile no.
The Following User Says Thank You to rathodhardik For This Useful Post:
Old 02-18-2013, 11:59   #7 (permalink)
Member: 337100
Sonork: 100.1606722
Thanks Meter: 75
any body pls tell me that how to karbonn A1+ hard reset wipe data factory reset mode?
thanxxxxxxxxx in advane
i forgot my pattern lock passwod.
Old 02-18-2013, 13:48   #8 (permalink)
Member: 1301079
Thanks Meter: 12
just remove beterry for 5 mints and insert it beck power on set and it will not ask any password dont touch any button go to security and make new pertern and now go to privesy and do reset all wipe all data it will wipe and reset
Old 02-18-2013, 14:18   #9 (permalink)
Member: 268772
Thanks Meter: 102
you can search at google....................
Old 03-02-2013, 13:38   #10 (permalink)
AFZALHASMI's Avatar
Member: 304342
Thanks Meter: 20
poswalm have you tested or simply westing time foum
Old 04-09-2013, 16:35   #11 (permalink)
Member: 1471333
Karbonn A1+ How To Remove Pattern Lock ?.
sir, plez tell me,
karbonn a1plus ,pattern lock solution
Old 05-10-2013, 15:00   #12 (permalink)
Member: 1301079
Thanks Meter: 12
no i have tested many time bro we are here to help each other not westting time i dont have time to waist bro
Old 05-16-2013, 19:32   #13 (permalink)
Member: 1838311
Sonork: 100.1638474
Thanks Meter: 103
if you have volcano box open it select spd select boot 6820 format phone 100000% removed google acount karbonn a1+
Old 05-17-2013, 05:33   #14 (permalink)
sangaistalin's Avatar
Member: 1474141
Sonork: 100.1647675
Thanks Meter: 66
android multi tool
android multi tool used to remove pattern unlock
Old 05-22-2013, 06:59   #15 (permalink)
inderpreet123's Avatar
Member: 647550
Sonork: 100.1611449
Thanks Meter: 31
android multi tool work in only fastboot mode
so if any have perfect idea to handreset a1+ then post hear don,t use geass
Page generated in 0.25465 seconds with 8 queries
