Karbonn A1+ : how to do the hard reset? how to hard reset? phone lock code problem...... please help http://telecomgyaan.com/wp-content/u...e-in-India.png |
volume up+power 5 sec ...........100% done |
volume up+power 5 sec ...........100% done not work with karbonn A1+... ANY OTHER SOLUTION PLS... |
volume up+power 5 sec ...........100% done Not working bro... after press volume up+power show Factroy test below Full Phone Test Item Test View Test Result Exit |
I have orignal flasher and flash file but the phone doesnt detect on original flasher. I think it needs modified cable instead of normal micro usb. As it is described in service center website "Use special cable to upgrade this phone". But cable schematic is not provided, only file and flasher is given. |
100 Volume Down + Menu key + Power key select option with volume down key wipe data/factory reset & use power key for select select option with volume down key yes -- dalete all user data & ur problem 101% solve. |
Karbonn a1+ Hard reset volume down + back button + powre button select wipe data 1000000% working........... |
B.R., B.Uttam |
android multi tools working only fast boot mode any other solution |
how to Karbonn A1+ g/c problem Quote:
B.R., B.Uttam |
SOLUTION FOR KARBONN A1+ PATTERN LOCK / FLASHING.. THINGS U NEED .... 1. VOLCANO BOX 2. KARBON A1+ FLASH FILE 3. UPGRADE DOWNLOAD (GREEN SPREADTRUM FLASHER) 4. SPREADTRUM DRIVER CHECK YOU KARBONN A1+ SOFTWARE VERSION SEE BACK LABEL... YOU CAN SEE THERE IS SW VERSION: 2.0.8 ,2.0.7 OR 2:0.3, 2.0.2, 1.0.9 ETC. DOWNLOAD FILES FROM SUPPORT WEBSITE ...HERE 1 STEP OPEN VOLCANO SOFTWARE(USE ANY VERSION) CONNECT YOUR PHONE GO TO DETECT TAB SELECT SPD/ANYKA CLICK DETECT BUTTON PRESS CONTINOUSLY VOLUME UP BUTTON OF PHONE .. YOU WILL SEE IN RIGHT SIDE WINDOW SPD DETECTED... AFTER DETECTED MINIMIZE THE VOLCANO SOFWARE OPEN UPGRADE SOFTWARE CLICK ON LOAD PACKET BUTTON (BIG ) SELECT FILE ... SELECT HW INFO.... (INCLUDED IN FIRMWARE) CLICK START DOWNLOADING BUTTON REMOVE ONLY CABLE FROM PHONE THEN REPLUG DOWNLOADING WILL START ... AFTER FLASHING COMPLETED YOU WILL SEE PASSED SHOW IN FLASHER.. REMOVE YOUR CABLE YOUR PHONE SUCESSFULLY FLASHED .... IF YOU FOUND ANY PROBLEM OR ANY REQUEST POST HERE .... BR. ARMAN RAZA |
A1+ Quote:
http://forum.gsmhosting.com/vbb/f824...sh-ok-1725550/ |
