Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 01-03-2013, 15:13   #1 (permalink)
Member: 1646875
Thanks Meter: 16
Karbonn A1+ : how to do the hard reset?
how to hard reset? phone lock code problem...... please help
The Following User Says Thank You to samip2066 For This Useful Post:
Old 01-28-2013, 20:48   #2 (permalink)
amit kanpur's Avatar
Member: 1033905
Sonork: amitsharma
Thanks Meter: 892
volume up+power 5 sec ...........100% done
Old 02-03-2013, 17:58   #3 (permalink)
Member: 747158
Thanks Meter: 13
not work with karbonn A1+...
ANY OTHER SOLUTION PLS...
Old 02-03-2013, 18:13   #4 (permalink)
Member: 747158
Thanks Meter: 13
Not working bro...
after press volume up+power show
Factroy test
below
Full Phone Test
Item Test
View Test Result
Exit
Old 02-03-2013, 20:04   #5 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 507
I have orignal flasher and flash file but the phone doesnt detect on original flasher. I think it needs modified cable instead of normal micro usb. As it is described in service center website "Use special cable to upgrade this phone". But cable schematic is not provided, only file and flasher is given.
Old 02-04-2013, 15:12   #6 (permalink)
avi4uni's Avatar
Member: 713765
Thanks Meter: 41
100
Volume Down + Menu key + Power key
select option with volume down key
wipe data/factory reset
& use power key for select
yes -- dalete all user data
& ur problem 101% solve.
Old 02-04-2013, 15:12   #7 (permalink)
avi4uni's Avatar
Member: 713765
Thanks Meter: 41
Old 03-19-2013, 16:00   #8 (permalink)
Crazy Poster
Member: 632701
Thanks Meter: 8
Karbonn a1+ Hard reset
volume down + back button + powre button
select wipe data
1000000% working...........
The Following User Says Thank You to nani1000 For This Useful Post:
Old 04-06-2013, 14:22   #9 (permalink)
sachinpatel's Avatar
Member: 1749874
Sonork: 100.1663210QQ:20249255921
Thanks Meter: 437
Download PZ286FM_KMOEB_karbonn_A1_FOREIGN_V2.0.2.rar from Sendspace.com - send big files the easy way
Download A1+sw tool 0807.zip from Sendspace.com - send big files the easy way
The Following User Says Thank You to sachinpatel For This Useful Post:
Old 04-06-2013, 15:17   #10 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Hello, use Android Multi Tools v1.02b this tool, very easy to remove pattern lock & Google A/C.
B.R.,
B.Uttam
The Following User Says Thank You to uttam4u2002 For This Useful Post:
Old 04-23-2013, 18:45   #11 (permalink)
Member: 1030416
Sonork: rinku_2k9
Thanks Meter: 17
android multi tools working only fast boot mode any other solution
The Following User Says Thank You to rinku_2k9 For This Useful Post:
Old 04-29-2013, 07:08   #12 (permalink)
Member: 886441
Sonork: 989090
Thanks Meter: 4
Thumbs up how to Karbonn A1+ g/c problem
B.R.,
B.Uttam
The Following User Says Thank You to ritesh_ritesh75 For This Useful Post:
Old 06-06-2013, 06:33   #13 (permalink)
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
Power on phone, connect with PC & Install ADB Drivers Then open Andriod multi tool & press 4 or 5 button on key board and Enter. u r problem solve.
B.R.,
B.Uttam
Old 09-03-2013, 13:59   #14 (permalink)
NAAZTELECOM's Avatar
Member: 1274132
Thanks Meter: 20
SOLUTION FOR KARBONN A1+ PATTERN LOCK / FLASHING..
THINGS U NEED ....
1. VOLCANO BOX
2. KARBON A1+ FLASH FILE
3. UPGRADE DOWNLOAD (GREEN SPREADTRUM FLASHER)
4. SPREADTRUM DRIVER
CHECK YOU KARBONN A1+ SOFTWARE VERSION SEE BACK LABEL...
YOU CAN SEE THERE IS SW VERSION: 2.0.8 ,2.0.7 OR 2:0.3, 2.0.2, 1.0.9 ETC.
DOWNLOAD FILES FROM SUPPORT WEBSITE ...HERE
1 STEP
OPEN VOLCANO SOFTWARE(USE ANY VERSION)
CONNECT YOUR PHONE
GO TO DETECT TAB
SELECT SPD/ANYKA
CLICK DETECT BUTTON
PRESS CONTINOUSLY VOLUME UP BUTTON OF PHONE ..
YOU WILL SEE IN RIGHT SIDE WINDOW SPD DETECTED...
AFTER DETECTED MINIMIZE THE VOLCANO SOFWARE
OPEN UPGRADE SOFTWARE
CLICK ON LOAD PACKET BUTTON (BIG )
SELECT FILE ...
SELECT HW INFO.... (INCLUDED IN FIRMWARE)
CLICK START DOWNLOADING BUTTON
REMOVE ONLY CABLE FROM PHONE THEN REPLUG
DOWNLOADING WILL START ...
AFTER FLASHING COMPLETED YOU WILL SEE PASSED SHOW IN FLASHER..
REMOVE YOUR CABLE
YOUR PHONE SUCESSFULLY FLASHED ....
IF YOU FOUND ANY PROBLEM OR ANY REQUEST POST HERE ....
BR.
ARMAN RAZA
Old 10-10-2013, 07:46   #15 (permalink)
jaijee's Avatar
Member: 450110
Thanks Meter: 187
A1+
Originally Posted by rajkilotra View Post
any one understand karbon a1+
all the above not workssssss... for pattern unlock
http://forum.gsmhosting.com/vbb/f824...sh-ok-1725550/
The Following User Says Thank You to jaijee For This Useful Post:
Page generated in 0.32582 seconds with 8 queries
