06-14-2013, 12:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | Karbonn A21 Dead. [Solution Need] NO ANY FASTBOOT MODE, NO ANY RECOVERY MODE NOT CHARGING, FULLY DEAD . WHEN CONNECT IN USB THERE IS (ZEUS Flash Device) ONLY SHOWS I TRY STOCK FLASHER AND FILE BUT NOT WORKING PLEASE HELP ME TO SOLVE THIS ISSUE THANKS |
07-09-2013, 15:59 | #2 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 291418 Status: Offline Thanks Meter: 1 | Quote:
qpst (qualcomm product support tool) can be used to fix bricked phones which is being detected as HS USB QDloader 9008.. Tools Needed:
Here is full tutorial Download link Source: XDA Last edited by ..::Nokian CareŽ::..; 07-09-2013 at 17:01. Reason: removed link | |
09-28-2013, 17:49 | #4 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2035883 Status: Offline Thanks Meter: 0 | operation failed I followed the instructions as said but nothing happens I waited for 2 hrs for phone to detect the drivers but in vain. DURING THE OPERATION PHONE WAS CONNECTED WITH USB CABLE AND NO PHONE BATTERY. SYSTEM DETAILS WINDOWS XP SP3 my phone details KARBONN A21 DETECTS AS QUAL COMM MMC COM4 |
11-16-2013, 15:58 | #5 (permalink) |
Junior Member Join Date: Jul 2013 Location: india
Member: 1971792 Status: Offline Thanks Meter: 0 | I AM GETTING THIS ERROR IMAGE DOWNLOAD FAILED. COOKIE(IF PRESENT) NOT RECEIVED I HAVE screen shot but i don`t know how to attach hear plzzz sir help me it`s urgent plzzzz plzzzz |
11-16-2013, 16:24 | #6 (permalink) |
Member: 1971792 Status: Offline Thanks Meter: 0 | failed with this error image download failed. cookie(if present) not received i have screen shot but i can`t know how to post hear plzz help me for fix this error plzzz plzzz |
12-03-2013, 13:32 | #8 (permalink) | |
Freak Poster Join Date: Dec 2009
Member: 1181433 Status: Offline Thanks Meter: 6 | Quote:
shows could not find file EMMcBLd.HEX on any search path | |
12-03-2013, 14:34 | #9 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | bro you need karbonn a21 bp firmware press vol down + power if mobile same as pic insert usb install driver see in device manager qualcom 9006 port use emmc write tool with bp firmware after write imei your mobile on if not on press volup power,this time your mobile enter in fast boot mode( green ) then mobile flash with ap firmware .......................... if mobile totally dead & device manager qualcomm 9008 com appear then use qpst tool and rename this two filename in qpst tool according to your phone bp firmware bp firmware folder inside .hex and .mbn file name open bp firmware folder select .hex file rename option and copy name and paste in qpst phone program flasher name same as pic mbn file name copy and past in qpst tool boot image mbn file load xml & patch file in a21 bp firmware same as pic select bp firmware in path 2 press download after this prosess your mobile not on your mobile enter in qpst download mode or fast boot mode and see in device manager qualcom 9006 port appear(auto convert 9008 to 9006) if enter qpst download mode agan flash bp firmware with emmc download tool then write ap in fast boot mode |
12-04-2013, 10:01 | #10 (permalink) |
Member: 1181433 Status: Offline Thanks Meter: 6 | press vol down + power mobile same as pic insert usb install driver see in device manager qualcom 9006 port how to use emmc write tool with bp firmware .......................... link for bp firmware and thanks a lot 4 reply |
12-04-2013, 12:47 | #11 (permalink) | |
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | Quote:
select bp firmware in emmc tool and run | |
12-07-2013, 21:57 | #15 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: kolkata
Member: 1050877 Status: Offline Thanks Meter: 115 | Quote:
After pressing Download a error msg Image Download Failed.Cookie(if present) not received How to solve | |
