Karbonn A21 hard reset http://www.gizbot.com/files/2012/10/...artphon-es.jpg Press Power key + Volume up key + Home Key and then select clear data. Regards, rahul_rocks3 |
karban a21 hard rest i try nmainy time but ok thish metthode 100% tested thishg solution |
karbonn a21 hardreset, not working for me |
A21 hard rset not working HOME KEY sensor touch after pressing these key only yellow display nothing else |
the proper steps for hard reset karbonn a21 hold volume + power and home button for 5 more seconds even after green screen appears than keep holding home and volume + button press power button 3 times continiously screen colour changes to red now release all button immediately now it goes to recovery do as of all required |
a21 flash file cervice centur in not avlable |
format karbonn a21 Press Power key + Volume up key + Home Key and then select clear data. ok power butan up dawun vollum key |
KARBONN A6 SUSES HARD RESET BY DRAGON BOX >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM39 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... UNTICK SCANPINOUT SETPINOUT VCC -1 USBD- 2 USBD+ -3 GND -4 |
hard reset done hold volume + power and home button for 5 more seconds even after green screen appears than |
Karbonn A21 Hard Reset Hard Reset: Press and hold VOLUME UP + POWER KEY now you see green screen dont release volume up key after 10 seconds you see red screen, now release Volume up key. now tou see recovery options. select wipe data with factory reset and press power key for 2 sec. now select yes and press power key for 2 second. now reboot device. |
Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.86 Update:14-05-26 Firmware Version:1.11 Connected OK. Connecting Internet... You use Latest Miracte Software 1.86 Connecting to Phone,Wait..ok checking info... Model:A21 Android Ver:4.0.4 ROOT OK! Reboot! Connecting to Phone,Wait..ok Wipe data... >>Done |
Karbonn S5(a21) Titanium Hard Reset 100% Done tested by me Press and hold VOLUME UP + POWER KEY now you see green screen don't release volume up key after 10 seconds you see red screen, now release Volume up key. now you see recovery options. select wipe data with factory reset and press power key for 2 sec. now select yes -- delete all user data and press power key for 2 second. now reboot device idrish911 |
