Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Karbonn
Old 11-28-2012, 05:53   #1 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Thanks Meter: 756
Karbonn A21 hard reset
Press Power key + Volume up key + Home Key
and then select clear data.
Regards,
rahul_rocks3
The Following 2 Users Say Thank You to rahul_rocks3 For This Useful Post:
Old 02-23-2013, 10:23   #2 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 203
karban a21 hard rest i try nmainy time but ok thish metthode 100% tested thishg solution
The Following User Says Thank You to rajakhank3 For This Useful Post:
Old 02-23-2013, 10:27   #3 (permalink)
Member: 1532854
Sonork: 100.1639591
Thanks Meter: 104
Unhappy
Regards,
rahul_rocks3
sir ji need solution for this tablet any ideahttp://forum.gsmhosting.com/vbb/f606...lp-me-1619015/
The Following User Says Thank You to oum2 For This Useful Post:
Old 03-23-2013, 07:44   #4 (permalink)
Member: 205776
Thanks Meter: 51
karbonn a21 hardreset, not working for me
Old 03-23-2013, 08:12   #5 (permalink)
sarasa's Avatar
Member: 693812
Thanks Meter: 25
A21 hard rset not working
HOME KEY sensor touch
after pressing these key only yellow display nothing else
Old 03-26-2013, 13:41   #6 (permalink)
Member: 988655
Thanks Meter: 12
the proper steps for hard reset karbonn a21
hold volume + power and home button for 5 more seconds even after green screen appears than keep holding home and volume + button press power button 3 times continiously screen colour changes to red now release all button immediately now it goes to recovery do as of all required
The Following 5 Users Say Thank You to pasha marks For This Useful Post:
Old 03-31-2013, 06:12   #7 (permalink)
harish1717's Avatar
Member: 332635
Sonork: 100.1648966
Thanks Meter: 48
a21 flash file cervice centur in not avlable
Old 04-03-2013, 15:10   #8 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
format karbonn a21
and then select clear data. ok power butan up dawun vollum key
Old 06-10-2013, 13:55   #9 (permalink)
Member: 1880249
Thanks Meter: 16
Old 09-26-2013, 15:15   #10 (permalink)
yogesha123's Avatar
Member: 905341
Thanks Meter: 63
KARBONN A6 SUSES HARD RESET BY DRAGON BOX
>>> USB Pinfind No need Hold Mobile Power key...
>>> Scanning Mobile USB Port...
>>> Detecting COM PortCOM39
>>> Connecting Mobile...
Mobile Connection Success...
Mobile Firmware Version:SPRD3
>>> Downloading First Boot...
>>> Mobile Info
Project ID :Spreadtrum Boot Block version 1.1
>>> Downloading Second Boot...
Baud Rate is Switched To:921600
Flash ID:00002CBC
Flash Size:20000000->512M
Flash Name:NAND_SamSungMT29C4G48MAZAPAKD
CPU Name:6820/8810
>>> Auto Formatting ...
Format_RuntimeNV...Fail.
Format_Cache...Fail.
Format_Misc...Fail.
Format_UserData...Success.
All Done...
UNTICK SCANPINOUT
SETPINOUT
VCC -1
USBD- 2
USBD+ -3
GND -4
The Following User Says Thank You to yogesha123 For This Useful Post:
Old 10-15-2013, 16:26   #11 (permalink)
AFZALHASMI's Avatar
Member: 304342
Thanks Meter: 20
hard reset done hold volume + power and home button for 5 more seconds even after green screen appears than
The Following 2 Users Say Thank You to AFZALHASMI For This Useful Post:
Old 12-02-2013, 13:36   #12 (permalink)
inderpreet123's Avatar
Member: 647550
Sonork: 100.1611449
Thanks Meter: 30
Karbonn A21 Hard Reset
Hard Reset:
Press and hold VOLUME UP + POWER KEY
now you see green screen dont release volume up key
after 10 seconds you see red screen, now release Volume up key.
now tou see recovery options.
select wipe data with factory reset and press power key for 2 sec.
now select yes and press power key for 2 second.
now reboot device.
Old 12-20-2013, 07:55   #13 (permalink)
Member: 742687
Sonork: sunilbansal
Thanks Meter: 10
Old 06-06-2014, 15:47   #14 (permalink)
AFZALHASMI's Avatar
Member: 304342
Thanks Meter: 20
Welcome to use miracle box(World's First Fuzzy Logic Based Tool)
SoftWare Version 1.86 Update:14-05-26
Firmware Version:1.11
Connected OK.
Connecting Internet...
You use Latest Miracte Software 1.86
Connecting to Phone,Wait..ok
checking info...
Model:A21
Android Ver:4.0.4
ROOT OK! Reboot!
Wipe data...
>>Done
Old 08-17-2014, 10:39   #15 (permalink)
idrish911's Avatar
Member: 1497850
Sonork: 100.1601368 QQID:21952428
Thanks Meter: 1,477
Karbonn S5(a21) Titanium Hard Reset 100% Done tested by me
now you see green screen don't release volume up key
now you see recovery options.
now select yes -- delete all user data and press power key for 2 second.
now reboot device
idrish911
Page generated in 0.36555 seconds with 7 queries
