06-03-2015, 14:49 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Karbonn A51+ After Flash With User Data File Set Dead (Solution Need) h/w ver: A350_v1.2 s/w ver: utla51+v01007(kitkat) problem - hang on logo after flash user data with this file ( Karbonn-A51+V01005-01-08-2014-(Kitkat) ) mobile now dead and only make mtk usb port need solution to recover |
06-03-2015, 14:52 | #2 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | first arrenge same working hand set and read with sector file viva Mtkdroid tool and flash with Sp tool Last edited by MyGSM World; 01-24-2016 at 14:29. Reason: QUOTE Removed. |
06-03-2015, 16:05 | #4 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Use This Firmware Version : UTLA51+v01005_01-08-2014 And Select All Files In SP Flash Tool, Not Only User Data. Post Result Please. | |
06-03-2015, 17:34 | #7 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Code: ============ Memory Detection Report =========== Internal RAM: External RAM: Type = DRAM Size = 0x10000000 (256MB/2048Mb) NAND Flash: Device Id = "[KINGSTON] KTN0403CS_TCR1" (17) Size = 0x20000000 (512MB/4096Mb) EMMC: ERROR: EMMC was not detected! ============ RAM Test ============ Data Bus Test: [D0] [D1] [D2] [D3] [D4] [D5] [D6] [D7] [D8] [D9] [D10] [D11] [D12] [D13] [D14] [D15] [D16] [D17] [D18] [D19] [D20] [D21] [D22] [D23] [D24] [D25] [D26] [D27] [D28] [D29] [D30] [D31] OK!! Address Bus Test: [A1] [A2] [A3] [A4] [A5] [A6] [A7] [A8] [A9] [A10] [A11] [A12] [A13] [A14] [A15] [A16] [A17] [A18] [A19] [A20] [A21] [A22] [A23] [A24] [A25] [A26] [A27] OK!! RAM Pattern Test : Writing ... 0x44332211, 0xA5A5A5A5, 0xA5A5A500, 0xA500A500, 0xA5000000, 0x00000000, 0xFFFF0000, 0xFFFFFFFF, OK!! Increment/Decrement Test: Writing... OK!! ============ NAND Test ============ Pattern Test (0x5A): |
06-04-2015, 13:28 | #10 (permalink) | |
Here It's Karbonn A51Plus (A51+) Firmware Version : UTLA51+v01007_15-10-2014 | |
06-04-2015, 13:41 | #11 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | @Mygsm world thanks for file downloading now and will post result soon @All successfully flashed with v01005(kitkat) file but still dead but mobile now open preloader port (finally able to repair preloader) after check above v01007 file i will post my report here (hope this file will successfully recover my mobile) And thanks to JorgeVla who share solution to repair preloader and thanks to moulnisky to mention this solution in this forum |
06-05-2015, 07:55 | #12 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Flash success but mobile in same condition dead And also preloader port not stable as normal mobile one time preloader port another time mtk usb port need to check h/w i think |
The Following User Says Thank You to blacky199 For This Useful Post: |
