Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Karbonn
Old 10-12-2013, 05:57   #1 (permalink)
Member: 1727103
Thanks Meter: 12
karbonn a51 pattern lock solution ?
anyone can tell me how to hard reset karbon a 51 ? I have pattern lock problem . how to get fast boot mode.
Old 10-12-2013, 06:31   #2 (permalink)
Member: 1727103
Thanks Meter: 12
Hello anyone have solution ?
Old 10-12-2013, 07:13   #3 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,591
vol down + pw go to faastboot
The Following User Says Thank You to sunilkumar70791 For This Useful Post:
Old 10-12-2013, 07:45   #4 (permalink)
Member: 1727103
Thanks Meter: 12
not going to fastboot with vol down and power.
Old 10-24-2013, 07:51   #5 (permalink)
Member: 1691337
Thanks Meter: 8
Karbonn A51 Pattren Remove Via Volcano Box - YouTube
The Following 2 Users Say Thank You to smartmobilecare For This Useful Post:
Old 11-10-2013, 11:37   #6 (permalink)
vkgupta96's Avatar
Member: 1695643
Sonork: 1651587:vk
Thanks Meter: 90
karbonn a51 pattren remove 10000% tested
format in miracle box ver 1.34
spd cpu 8810/6820
press vol up + pwr
The Following User Says Thank You to vkgupta96 For This Useful Post:
Old 11-13-2013, 03:43   #7 (permalink)
satwindershine's Avatar
Member: 1562820
Thanks Meter: 22
Post only right and tested post
Old 11-13-2013, 03:46   #8 (permalink)
Member: 1562820
Thanks Meter: 22
post driver link karbonn a51 plz
spd cpu 8810/6820
press vol up + pwr
karbonn driver link plz
Old 11-13-2013, 03:47   #9 (permalink)
Member: 1562820
Thanks Meter: 22
Need karbonn a51 flash file plz
Old 11-13-2013, 07:25   #10 (permalink)
Member: 1562820
Thanks Meter: 22
Detection initiated...
Vcc: null
Gnd: 5
Analyzing D+ and D-...
D+ = 3, D- = 2
Analyzing USB device, please wait...
Find USB device:SCI USB2Serial (COM60), (VID_1782&PID_4D00)
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.1
Boot downloaded.
Flash ID: 00AD00BC
Flash Type:[Hyundai] NAND_HY27UT088G2A
FLASH LEN:0x20000000
>>Set to Factory successfully.
press vol + and connect volcano box and format
Old 11-14-2013, 13:34   #11 (permalink)
Member: 1181433
Thanks Meter: 6
done by volcano v2.3.9
100% ok
Old 11-14-2013, 14:09   #12 (permalink)
Member: 1691337
Thanks Meter: 8
Done with volcano just
Select spd cpu 6810....
And format
Boot key is volume up
Sent from my iPhone using Tapatalk
Old 12-01-2013, 08:11   #13 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 295
spd cpu 8810/6820
press vol up + pwr
yes it work look it---
Uploaded with ImageShack.us
Old 12-09-2013, 09:59   #14 (permalink)
khehra.jassi's Avatar
Member: 1395786
Sonork: 100.1621056
Thanks Meter: 16
D+ = 3, D- = 2
Find USB device:SPRD U2S Diag (COM81), (VID_1782&PID_4D00)
Boot downloaded.
Boot downloaded.
mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 250m(system),130m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory)
Analysis flash internal data successfully.
Old 12-30-2013, 16:56   #15 (permalink)
Member: 1713651
DONE WITH VOLCANO 2.1.1 VERSION
first select built in boot (6820/8810) then select auto-detect pinout then
connect by pressing (volume up and power on button)
Vcc: null
Gnd: 1
D+ = 3, D- = 4
Detection D+/D- with 1.50 seconds.
Continue to detect BOOT pin...
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
BOOT(Pull Down) = 2
Setting...
Find USB device:SPRD U2S Diag (COM36), (VID_1782&PID_4D00)
Pinouts setting complete!
Boot downloaded.
Boot downloaded.
Flash ID: 00AD00BC
Page generated in 0.37482 seconds with 7 queries
