01-31-2014, 17:48 | #16 (permalink) |
Junior Member Join Date: May 2009
Member: 1036150 Status: Offline Thanks Meter: 10 | Karbonn a6 hard reset done connect phone with volcano box cable , click auto-detect presh volume + than run button use v2.0.0 tested |
02-05-2014, 07:33 | #18 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2121139 Status: Offline Thanks Meter: 1 | use volcano 2.0.8 box volume + is boot key for this phone press key insert usb cable detect phone after detecting format it...... your phone will be ok |
The Following User Says Thank You to andrewsmith007 For This Useful Post: |
08-25-2014, 13:25 | #25 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 24 | Karbonn A6+ Karbonn A6+ Reset done by volcano select spd 6802/8810 uncheck auto detect pinout hold volume down insert usb v8 cable and click run read info ok then format in same method |
10-05-2014, 14:55 | #27 (permalink) |
Junior Member Join Date: Mar 2014 Location: phaltan maharashtra
Member: 2152338 Status: Offline Sonork: 1653962 Thanks Meter: 5 | karbon a6 pattern unlook done gpg dragun box >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:1, 2, 3, 5, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM139 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
11-07-2014, 12:32 | #30 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | |
