Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 12-21-2013, 16:17   #31 (permalink)
Member: 1676810
any one give me a karbonn a6 flash file link. v1.22 or 1.21
Old 02-11-2014, 08:09   #32 (permalink)
Member: 502243
Thanks Meter: 2
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.1
Detection initiated...
Vcc: null
Gnd: null
Analyzing D+ and D-...
D+ = 4, D- = 3
Detection D+/D- with 4.05 seconds!
Analyzing USB device, please wait...
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
Setting...
Find USB device:SCI USB2Serial (COM22), (VID_1782&PID_4D00)
Pinouts setting complete!
Boot downloaded.
but not done
Old 02-11-2014, 08:27   #33 (permalink)
Member: 1530628
Thanks Meter: 4
update driver corctly100% format done
Old 02-14-2014, 08:46   #34 (permalink)
Member: 1315082
Thanks Meter: 16
Boot downloaded.
Vcc: null
Gnd: null
D+ = 4, D- = 3
Setting...
Boot downloaded.
but not done
First Read info then format tested by me
Old 02-15-2014, 20:09   #35 (permalink)
Member: 492824
Thanks Meter: 35
urget need file ver 1.15
after formet my phone hang on karbon logo
afer few mints its dead
pls help me
Old 02-16-2014, 07:54   #36 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
pls help me
not found this file you try 1.16 1.22
Old 06-08-2014, 12:37   #37 (permalink)
Crazy Poster
Member: 1908783
Thanks Meter: 17
vol +, voi - preess drivar canent hoa
Old 06-08-2014, 12:39   #38 (permalink)
Crazy Poster
Member: 1908783
Thanks Meter: 17
Boot downloaded.
Vcc: null
Gnd: null
D+ = 4, D- = 3
Setting...
Boot downloaded.
VolcanoTool_v2.4.4 try 100000%%%%% ok test mi
Old 07-30-2014, 13:29   #39 (permalink)
Member: 1886551
Thanks Meter: 2
karbonn a6 google account remove to miracle succes full format
v+ then power ket enjoy
Old 07-30-2014, 15:07   #40 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Watch it simple way Thanks Mr. Umesh_Arora
http://forum.gsmhosting.com/vbb/f781...flash-1742542/
use update tool "UPGRADEDOWNLOAD_R2.9.7003" or write with any china box
http://www.4shared.com/rar/Ha2xTetbb...D_R297003.html
Reset karbonn a6 file link karbonn a6_reset file - Download - 4shared
Old 08-24-2014, 05:53   #41 (permalink)
Member: 2143664
Thanks Meter: 2
1. Charge the battery 100%.
2. Turn off your KArbonn Andorid phone. Turn ON the device by pressing and holding the VOLUME UP key and the power key together until the phone shortly vibrates.
3. When Android system recovery menu appears, release VOLUME key.
4. Highlight wipe data/Factory reset using volume key.
5. Confirm with Power or Cancel using BACK key.
6. After hard reset is done, highlight reboot system now and confirm your selection.
Note! All data will be deleted!
Karbonn A6 hard reset menu option
You can reset your phone to its factory defaults. When you reset your phone, the data stored in your phone will be erased.
To reset your phone:
1. Tap Application Drawer > APPS tab > Settings > Backup & reset.
2. Tap Factory data reset > Reset phone > Erase everything to reset the phone
Android Factory reset Backup and reset1Android Factory reset Backup and reset2Android Factory reset Backup and reset3
Old 10-09-2014, 13:16   #42 (permalink)
Member: 1403528
Sonork: ghiklo
Thanks Meter: 7
successfull with gpg dragon thanks gpg team
>>> USB Pinfind No need Hold Mobile Power key...
>>> Scanning Mobile USB Port...
>>> Detecting COM PortCOM22
Driver Name->>>SPRD U2S Diag
>>> Connecting Mobile...
Mobile Connection Success...
Mobile Firmware Version:SPRD3
>>> Downloading First Boot...
>>> Mobile Info
Project ID :Spreadtrum Boot Block version 1.1
>>> Downloading Second Boot...
Baud Rate is Switched To:921600
Flash ID:00002CBC
Flash Size:20000000->512M
Flash Name:NAND_SamSungMT29C4G48MAZAPAKD
CPU Name:6820/8810
>>> Auto Formatting ...
Format_RuntimeNV...Fail.
Format_Cache...Fail.
Format_Misc...Fail.
Format_UserData...Success.
All Done...
Old 11-21-2014, 02:22   #43 (permalink)
rudradeb's Avatar
Member: 1314041
Thanks Meter: 43
A 6 formatting problem
>>> Getting Mobile Connection Info...
VCC Pin:
GND Pin:5,
Signal Pin:1, 2, 3,
>>> Scanning Mobile PinOut...
USB Pin Out: D+:3 D-:2
HardWare:VID:17_82 PID:4D_00
This is a Spreadtrun chip set...
>>> Detecting COM PortCOM4
Driver Name->>>SCI USB2Serial
Error CODE:00--> CMD_EERPR --> TIMEOUT
Old 01-23-2015, 10:31   #44 (permalink)
Crazy Poster
Member: 1780708
Sonork: 62645
Thanks Meter: 7
karbonn a 6unlock done ...
use gpg 100% tested bye me
spd 8810 ,,,, -6820 booot key vol - +
VCC Pin:
GND Pin:5,
Signal Pin:1, 2, 3,
>>> Detecting COM PortCOM23
>>> Mobile Info
Flash ID:00002CBC
CPU Name:6820/8810
>>> Auto Formatting ...
Format_Misc...Fail.
All Done...
The Following User Says Thank You to madhav2all For This Useful Post:
Old 02-08-2015, 12:24   #45 (permalink)
Member: 2241654
Thanks Meter: 6
volcano box
1st go to spd tab
2 select 8810/6820
budrate 460800
then format prees vol- buttun
100 %%% working
Page generated in 0.24126 seconds with 8 queries
