02-11-2014, 08:09 | #32 (permalink) |
Junior Member Join Date: May 2007 Location: Hoshiarpur, Punjab
Member: 502243 Status: Offline Thanks Meter: 2 | Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Detection initiated... Vcc: null Gnd: null Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 4.05 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM22), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... >>Spreadtrum Boot Block version 1.1 but not done |
02-14-2014, 08:46 | #34 (permalink) | |
Freak Poster Join Date: May 2010
Member: 1315082 Status: Offline Thanks Meter: 16 | Quote:
06-08-2014, 12:39 | #38 (permalink) |
Crazy Poster Join Date: Mar 2013
Member: 1908783 Status: Offline Thanks Meter: 17 | Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Detection initiated... Vcc: null Gnd: null Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 4.05 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM22), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... >>Spreadtrum Boot Block version 1.1 VolcanoTool_v2.4.4 try 100000%%%%% ok test mi |
07-30-2014, 15:07 | #40 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Watch it simple way Thanks Mr. Umesh_Arora http://forum.gsmhosting.com/vbb/f781...flash-1742542/ use update tool "UPGRADEDOWNLOAD_R2.9.7003" or write with any china box http://www.4shared.com/rar/Ha2xTetbb...D_R297003.html Reset karbonn a6 file link karbonn a6_reset file - Download - 4shared Last edited by sr8787; 07-30-2014 at 15:15. |
08-24-2014, 05:53 | #41 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2143664 Status: Offline Thanks Meter: 2 | 1. Charge the battery 100%. 2. Turn off your KArbonn Andorid phone. Turn ON the device by pressing and holding the VOLUME UP key and the power key together until the phone shortly vibrates. 3. When Android system recovery menu appears, release VOLUME key. 4. Highlight wipe data/Factory reset using volume key. 5. Confirm with Power or Cancel using BACK key. 6. After hard reset is done, highlight reboot system now and confirm your selection. Note! All data will be deleted! Karbonn A6 hard reset menu option You can reset your phone to its factory defaults. When you reset your phone, the data stored in your phone will be erased. To reset your phone: 1. Tap Application Drawer > APPS tab > Settings > Backup & reset. 2. Tap Factory data reset > Reset phone > Erase everything to reset the phone Android Factory reset Backup and reset1Android Factory reset Backup and reset2Android Factory reset Backup and reset3 |
10-09-2014, 13:16 | #42 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1403528 Status: Offline Sonork: ghiklo Thanks Meter: 7 | successfull with gpg dragon thanks gpg team >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM22 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
11-21-2014, 02:22 | #43 (permalink) |
Freak Poster Join Date: May 2010 Location: pokhara,nepal
Member: 1314041 Status: Offline Thanks Meter: 43 | A 6 formatting problem >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM4 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version: >>> Downloading First Boot... Error CODE:00--> CMD_EERPR --> TIMEOUT |
01-23-2015, 10:31 | #44 (permalink) |
Crazy Poster Join Date: Jul 2012 Location: india Age: 40
Member: 1780708 Status: Offline Sonork: 62645 Thanks Meter: 7 | karbonn a 6unlock done ... use gpg 100% tested bye me spd 8810 ,,,, -6820 booot key vol - + >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM23 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
The Following User Says Thank You to madhav2all For This Useful Post: |
02-08-2015, 12:24 | #45 (permalink) |
Junior Member Join Date: Aug 2014 Location: Amethi u.p india Age: 31
Member: 2241654 Status: Offline Thanks Meter: 6 | volcano box 1st go to spd tab 2 select 8810/6820 budrate 460800 then format prees vol- buttun 100 %%% working Last edited by ashu20; 02-08-2015 at 12:30. |
