Karbonn A9+ Flash file and tools These are Stock and Modded Roms for Cherry Mobile Flare/Karbonn A9+. Use Android AIO Flasher to flash it. AIO Flasher Download form here Cherry Mobile Flare/Karbonn A9+ Firmware download links 1: A9+ boot and recovery img 2: Flare boot n recovery img 3: Flare system img 4: Flare System img Modded A9+ 5: Drivers Known Bugs : EVERYTHING WORKING Screen Flickers because of changing res files to reduce the recovery size. You have to tolerate that KEY COMBINATION Volume up is Back Volume down is scroll down Power Key is SELECT tutorial 1: Turn off the device. 2: Press Volume Up+Power until you see green screen (fastboot) 3: Connect USB and install Drivers 4: Open AIO Flasher In Console (Green) Type If you see your device then Select Boot > Select Boot.img> Click Erase > Flash Select Recovery > Select Recovery.img> Click Erase > Flash Select System > Select System.img> Click Erase > Flash Finally from Reboot Menu Select "From Fastboot" > Click Reboot Wait n Enjoy Here is Video if video not showing here is full link: Cherry Mobile Flare(S100) Latest Firmware Offline Update Flashing Tutorial - YouTube As ROM is for Cherry Flare, I am posting Apps from Indian version Karbonn A9+. Quote:
BR: King.of.gsm |
B.R., B.uttam |
karbonn a9+ How to flash Dead karbonn A9+? Handset not power on But when i connect with pc asking usb driver. How to recover it?kar how to fast mod |
AIO Flasher not in work plz help me |
how to slove " ENTRY QPST DOWNLOAD" IN KARBONN K9 |
need Karbonn A21 Flash file and tool |
how to flash karbonn a12 please can anyone upload flash tool & file |
android aio flasher not work plz help me |
Stock Rom Needed.. Hi, I want Stock Rom (System image) or Nandroid backup files of Karbonn A9+.. Plzz... Plzz upload it.. Thanks in Advance.. |
Pllzzzzzzzzzz help,, plzzzzzzzzzz upload Stock System image or Nandroid backup files of A9+.... |
karbon a9 pls update flasher & file |
How to flash Dead karbonn A9+? Handset not power on But when i connect with pc asking usb driver. How to recover it? same problem here if any1 solved this problem then plz share |
Karbonn A9+ Flash 100% sucessful........... |
