Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 01-02-2014, 04:53   #1 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 42
Karbonn A90 Pattern Lock Solution
Hello friends, Karbonn A90 Pattern Unlock done with Gpgdragon 3.38c.
>First Click Spd Tap and Android 6820 than Read info with gpg original cable.
>Than its hang on scanning usb ports
>than Remove phone and put battery and insert modified cable for spreadtrum
>Now same do for format. and click only userdata your problem solved.
Only thanksss
The Following User Says Thank You to purshottam For This Useful Post:
Old 03-18-2014, 12:36   #2 (permalink)
Member: 1794967
Thanks Meter: 3
a90 firmware needed................
Old 03-24-2014, 10:27   #3 (permalink)
Member: 1712309
Sonork: 8f580cbf3792776ff9df6d34b
Thanks Meter: 8
bhai mircale solve this problem otherwise flash your set by og flaser
serch moulnisky.in
Old 04-23-2014, 14:03   #4 (permalink)
rameshwarpooja's Avatar
Member: 1311498
Sonork: 100.1662995
Thanks Meter: 513
Old 07-05-2015, 08:10   #5 (permalink)
CRM
Member: 1176826
Sonork: 100.1604160
Thanks Meter: 60
Format With Volcano
When You Do Read Info It Will Show Analysis Fail
but no problem
Do format
100% Tested Solution
Page generated in 0.35658 seconds with 8 queries
