01-27-2016, 06:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: allahabad shankargarh u.p.
Member: 865141 Status: Offline Thanks Meter: 140 | Karbonn K9(M) Firmware MT6261 [Available] plz help me all frends..... mtk ic 6261 h/w version k209_1_10 s/wverson -karbon _k9neswmj_v20020 |
01-27-2016, 22:26 | #2 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, There Is To Much Version For K9 M. But I Found Two Compatible Version. (1) : KARBONN_K9NEWMJ_V0020 (2) : KARBONN_K9NEWM_02_V0020 |
The Following User Says Thank You to MyGSM World For This Useful Post: |
03-06-2016, 21:27 | #4 (permalink) |
No Life Poster Join Date: May 2014 Location: Tamil_Nadu Rasipuram
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | karbonn K9 (M) firmwear need karbonn K9 (M) firmwear need S/W - KARBONN_K9NEWMJ_V0020 H/W - K209_1_10 |
The Following User Says Thank You to dineshras For This Useful Post: |
08-22-2016, 11:45 | #6 (permalink) |
No Life Poster Join Date: May 2016 Location: ..:: BHARATH ::.. Age: 34
Member: 2569641 Status: Offline Sonork: WHATS APP & F.B Thanks Meter: 657 | karbon k9 (m) mt 6260 8.0 mb flash file need s/w ver..karbonn_k9newm_v0013 h/w ver..k209_1_10 any one give me link plz.... |
08-24-2016, 00:02 | #7 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
First Try With Above Firmware Version & Post Result Please. If Won't Work Then We'll Upload Same Version As Your Requested. | |
09-03-2016, 22:15 | #9 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, That's Factory Firmware, Only Flash By FlashTool_v5.1312.00. If You Need Box Firmware, Please Ask In Box Support Section. |
02-16-2019, 06:55 | #10 (permalink) |
Junior Member Join Date: Aug 2016 Location: INDIA Age: 30
Member: 2610358 Status: Offline Thanks Meter: 2 | Karbonn k9new {m} flash file 8mb need urjent ======= Flash Files set for flashing : [ MCU ] : VSUN60A_11B_PCB01_GPRS_MT6260_S00.KARBONN_K9NEWM_0 2_V0018.BIN.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 327CC9AF196D9EA7DEAF4F33048844C7 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 File_Info : VSUN60A_11B_PCB01_gprs_MT6260_S00.KARBONN_K9NEWM_0 2_V0018.bin FileVersion : Karbonn_K9NEWM_02_V0018 Flash now Erase region , wait ... Write data , wait ... Write : VSUN60A_11B_PCB01_GPRS_MT6260_S00.KARBONN_K9NEWM_0 2_V0018.BIN.bin Done! Elapsed: 00:00:46 Reconnect Power/Cable! Finish at : [2/16/2019 / 11:13:43 AM] |
