02-19-2015, 17:17 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Karbonn Sparkle V Hardreset + Bootloader unlocking + custom recovery Karbonn Sparkle V Hardreset + Bootloader unlocking + custom recovery Download ADB Fast Boot DriverHere * 1st put yur mob in fastboot mode by holding vol up+ pwr (for choose option use vol up for select vol dwn) * Open adb folder hold shift right to open command window here *Enter Below given command Fastboot devices (check mobile detected or not 1st) fastboot oem unlock (check yur mobile to select ) fastboot format userdata fastboot reboot *After reset if yu need relock yur bootloader again fastboot oem lock Procedure for recovery installation Download recovery here cwm recoveryphlz recovery * Copy the recovery.img to adb folder * Run below given command after unlock bootloader fastboot flash recovery recovery.img Last edited by jamesjerss; 02-23-2016 at 11:33. |
The Following 4 Users Say Thank You to jamesjerss For This Useful Post: |
08-12-2016, 05:31 | #9 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Mumbai
Member: 2524325 Status: Offline Sonork: 100.1671897 Thanks Meter: 179 | Or if the not have box then go on ADB folder & (shift+mouse right click> Run as CMD) after open CMD add following command : Fastboot oem Unlock > hit enter & prese volume up key of Mob you get boot Unlock Sent from my Nexus 5 using Tapatalk |
01-22-2017, 13:11 | #10 (permalink) | |
Crazy Poster Join Date: Nov 2015 Location: Jaipur
Member: 2486788 Status: Offline Thanks Meter: 22 | Quote:
The Following User Says Thank You to shareef86 For This Useful Post: |
