Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 03-06-2015, 13:50   #1 (permalink)
Member: 2321039
Thanks Meter: 3
Karbonn Titanium S1Plus (S1+) Firmware & Process. [Available]
need flash file
hw : v1.1
sw : karbonn_s1 plus_120614_v0024
pls share good flash file
The Following 2 Users Say Thank You to sunstarmobiles For This Useful Post:
Old 03-06-2015, 15:18   #2 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Here It's Karbonn Titanium S1 Plus Firmware:
-----Jaina-----
Version: C230wJA_0000_4.4_1.0T06_20140723-1607_SH : DOWNLOAD
Version: C230wJA_0000_4.4_1.2T12_20140911-2050_SH (Dead Issue): DOWNLOAD
-----UTL-----
Version: C230wJA_0000_4.3_1.7T24_20140612-1010_SH : Pending
Version: C230wJA_0000_4.3_1.8T25_20140703-1243_SH : Pending
Old 09-04-2015, 08:45   #3 (permalink)
Member: 740513
Thanks Meter: 2,544
Post
Originally Posted by mygsm world View Post
Dear Friend,
Newer Version Available On GsmHosting Support Area.
Welcome to the ./downloads/Karbonn/S1 Plus/KitKat/ folder of GsmHosting support area
How to flash bro ?
Old 09-04-2015, 18:34   #4 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Originally Posted by atulharnal View Post
How to flash bro ?
Dear Friend,
1. Run Adb.exe
2. Connect Phone Wait Till Driver Install
3. Remove Cable / Switch Off Your Phone
3. Click On => c230wJA_fastboot_flash_all.bat
4. Connect Your Phone With Battery In Switch Off Mode
5. Wait Till Flash Complete.
Also You Can Flash With QPST Because It Has Qualcomm MSM8212
Old 12-22-2015, 09:15   #5 (permalink)
Member: 1386945
Thanks Meter: 2
karbonn Titanium S1 plus dead boot Qualcomm HS-USB QDLoader 9008 plz help
karbonn titanium s1 plus dead plz help
showing Qualcomm HS-USB QDLoader 9008 in ports
Old 12-22-2015, 16:50   #6 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
If It's Completely Dead & Create Com Port So Flash By QPST.
Here It's S1Plus_Dead_Flashing_Procedure : DOWNLOAD
Last edited by MyGSM World; 04-18-2016 at 19:00. Reason: Corrected & Procedure Link Added.
Old 01-14-2016, 12:58   #7 (permalink)
Member: 2464111
Sonork: 100.1671169
Thanks Meter: 16
adb.exe cannot see in the downloaded firmware after extracting only adb is shown..
can i do sd update ???
NEED HELP ANYONE FLASHED BEFORE PLZZ POST TITANIUM S1 PLUS FLASHING PROCEDURE.....
Old 01-14-2016, 14:45   #8 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Now Try With This Method.
First Of All, Install ADB Driver "adb.exe" Inside Firmware Folder.
Power On The Cellphone And Tap To On USB Debugging In Developer Option.
Insert USB Cable Into Cellphone (Power On Mode) And Click On "c230wJA_fastboot_flash_all.bat" File To Start Software Update.
The Following User Says Thank You to MyGSM World For This Useful Post:
Old 01-16-2016, 12:34   #9 (permalink)
Member: 2464111
Sonork: 100.1671169
Thanks Meter: 16
no luck some other solution plzzzzzz....
how to put s1 plus to fastboot mode volume+ and power cannot solved....
plzz solved
Old 01-16-2016, 20:40   #10 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
plzz solved
Dear Friend,
What's The Problem In Your Cellphone ?.
Last Option Flash By QPST_2.7.410
Old 02-22-2016, 12:37   #11 (permalink)
abubaker773's Avatar
Member: 1811976
Sonork: abubaker773
Thanks Meter: 38
Dear Friend,
1. Run Adb.exe
Above Process Working 1000%.
Old 06-30-2016, 11:49   #12 (permalink)
Member: 2399967
Thanks Meter: 13
How to flash karbonn s1 plus
I have karbonn s1 hang on logo how to flash it
Old 06-30-2016, 22:26   #13 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend @shivampal,
Read Whole Thread, From Beginning. Always Use "SEARCH" Button Before Posting.
__________________
Read The Rules Carefully!!!
WBR
MyGSM World.
Old 04-14-2017, 09:15   #14 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 228
same problm here when i inset cable set automatic on & still on logo
Set problm still on Karbonn logo
Old 03-28-2018, 16:55   #15 (permalink)
mohdfaizan987's Avatar
Member: 2376362
Sonork: 1664031:mohd
Thanks Meter: 49
Dear Friends & Support Team Need Help I Have Karbonn Titanium S1Plus.
After Flashing Its Hang On Logo,Need Help If Any One Have Tested Flash File With Tool,
so Please Share With me
Page generated in 0.21029 seconds with 8 queries
