06-27-2014, 16:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Karbonn Titanium S5 Dead Solution [Available] Condition :- Dead Reason:- Customer say he format the mobile drive with laptop after that set is dead When i connect the set show this HELP ME TI REVIVE IT I DOWNLOAD THE FLASHFILE & QST Last edited by MyGSM World; 03-03-2016 at 22:57. Reason: Title Modified. |
06-28-2014, 04:54 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: I.N.D.I.A
Member: 385162 Status: Offline Thanks Meter: 598 | look here and repair it via riff box... http://forum.gsmhosting.com/vbb/f634...ir-ok-1828775/ |
06-28-2014, 06:15 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2012 Location: COOCHBEHAR,WB
Member: 1714311 Status: Offline Sonork: 100.1604096 Thanks Meter: 271 | press volume up and power and see "RESET FOR ENTRY QSTP DOWNLOAD mode comes or not.if comes i will provide its stock firmware |
06-28-2014, 07:08 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Flash files are available on the support since always. Welcome to the ./downloads/Karbonn/S5_Titanium/ folder of GsmHosting support area BR Alex |
06-29-2014, 05:40 | #7 (permalink) |
Member: 385162 Status: Offline Thanks Meter: 598 | HERE IS PROCEDURE try and post result Titanium S1 & S5 Download Procedure - Download - 4shared - dharmesh Solanki |
07-18-2014, 19:07 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Why don't you download the guide in the post just before yours? http://forum.gsmhosting.com/vbb/10406347-post7.html BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
08-10-2014, 08:15 | #10 (permalink) | |
No Life Poster Join Date: Jul 2007
Member: 551619 Status: Offline Thanks Meter: 136 | Quote:
Your Problem Solved or Not..??? I've Set with Same Condition and Need Solution... Set Current Condition : Dead [after Format Internal Drive with PC] When Connect to PC Shows : S5.png Tried to Flash with QualFast v2.0.5 but QualFast Unable to Run : Qualfast.png [Tried to Run as Administrator but Same] OS : Windows 7 64bit Need Help to Solve this... | |
08-10-2014, 08:31 | #11 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
BR Alex | |
08-10-2014, 18:43 | #14 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
If You Are Sure It's Dead After Format "Internal Drive With PC" On Windows 7. You Can Revive It Without JTAG By BP Part Flashing On Windows XP. You Can't Flash On "Windows 7". First Flash "BP" Part Then "AP" Part. | |
08-11-2014, 08:25 | #15 (permalink) | |
Thanks for Reply Set Came for LCD Problem at My Friend's Shop [Broken LCD] After Replace LCD he was Unable to Make Incoming/Outgoing Calls with Full Network but Calls OK with Old LCD so he gave it to me for Flash by mistake I Formatted its Internal Partition and Now Set is Dead Already Downloaded Firmware and Tool from : Welcome to the ./downloads/Karbonn/S5_Titanium/ folder of GsmHosting support area but QualFast Unable to Run [Not Sure if it its works with XP or not] if Need other Tool for Flash Please Post Link... | |
