12-25-2017, 09:01 | #1 (permalink) |
Crazy Poster Join Date: Jul 2016 Location: india
Member: 2601459 Status: Offline Thanks Meter: 9 | Karbonn A41 Power Flashing Error i am flashing with this firmware link below https://drive.google.com/uc?id=0B7P4...xport=download i am getting this error.... image below https://imgur.com/bz938uy i also try in miracle but miracle write error also try in tool tick on erase all flash but no luck device is on hang on logo |
12-26-2017, 15:54 | #4 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, After Facing This Error Disconnect The Handset & Connect Again With Boot (Volume Down) Key. Insert USB Cable Then Battery. Important Thing Is Do "NOT" Stop Or Close The Flash Tool After Facing An Error. Post Result Please... |
The Following 3 Users Say Thank You to MyGSM World For This Useful Post: |
12-26-2017, 17:22 | #5 (permalink) | |
Member: 2601459 Status: Offline Thanks Meter: 9 | Quote:
Returned to customer.... And tnx for this useful info .... Next time when i facing same isue in another spd device i definitely try this trick Sent from my Redmi 3S using Tapatalk | |
12-27-2017, 08:01 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | yes many new karbonn spedtrum phones not getting flashed in research downloader. only service center people doing this hang issues. if somebody knows the solution please post it wbr |
12-27-2017, 14:10 | #7 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear @bhuvanele, Do You Have Karbonn A41 Power With Hang At Logo Problem? If Yes So Use Above Method. If In Case Not Work So Post Here Please, We'll Provide You The Working Solution. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
01-02-2018, 08:05 | #9 (permalink) |
Major Poster Join Date: Apr 2015 Location: india Age: 26
Member: 2378338 Status: Offline Thanks Meter: 3 | karbonn a41 power flashing problem stuck on system flashing Capture_zpsu5yorkgu.png Photo by sajanbharavad | Photobucket please help bro |
01-05-2018, 08:47 | #10 (permalink) |
Member: 237210 Status: Offline Thanks Meter: 90 | after repairing it with FACTORYDOWNLOAD_R19.17.4301_P1 , use SPD_Upgrade_Tool_R4.0.0001 tool for flashing wbr |
The Following User Says Thank You to bhuvanele For This Useful Post: |
01-05-2018, 15:10 | #11 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Don't Require To Use Other Tool Like You Wrote In Your Post. Once Again Going To Write Procedure In Different Ways. After Error Just Remove The Battery Then Press & Holding Volume Down Then Insert The Battery, Again Error, Remove The Battery Then Press & Holding Volume Down Key Then Insert The Battery Again. Important Thing Is "DO NOT STOP" The Flash Tool While Using Above Procedure. |
01-27-2018, 13:14 | #15 (permalink) |
Freak Poster Join Date: Dec 2009 Location: surat
Member: 1187075 Status: Offline Thanks Meter: 10 | hang on logo and i also use shorting cable n volume down press n battery is fully charged 4.0v Last edited by milanlove; 01-27-2018 at 13:20. |
The Following User Says Thank You to milanlove For This Useful Post: |
