2G Latest Models Models made in 2011, 2012, 2013 year. |
03-14-2014, 19:37 | #16 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1. Turn Samsung C3590 with a not accepted by the device card , ie another operator (if the card has no PIN to enter it ) . 2 . The phone should ask unlock code . 3 . When prompted for the unlock code ( unlock code or network code or nck code ) you must enter the NCK / Network code and press OK . ! Sometimes the NCK code does not work ! In this situation , you need to enter Unfreeze / Defreeze code and press OK ( " incorrect code " will appear ) and then enter the NCK code and press OK ( " correct code " will appear) . 4 . The phone is already released. If Samsung C3590 does not ask for unlock code or no screen appears to enter you must: 1. Turn Samsung C3590 with a card not accepted by the device , that is another operator (if the card has no PIN to enter it ) . 2 . Mark one of the two sequences : # 7465625 * 638 * NCK / Network # code or * # 7465625 * 638 * NCK / Network # code 3 . The phone is already released. If the device does not ask for unlock code or any screen to enter you must: 1. Turn Samsung C3590 with a card not accepted by the device , that is another operator (if the card has no PIN to enter it ) . 2 . Enter the combinations below: # 0199 * Unfreeze / Defreeze # # 0111 * NCK / Network # # 0121 * SCK / Subprovider # # 0133 * SPCK / Provider # 3 . The phone is already unlocked . : If after entering the codes , the phone error code , resetealo after card should work with other operator ! |
03-14-2014, 19:43 | #17 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | How to enter code in Samsung C3590 ? You can enter unlock code using three following instructions: 1. Insert a foreig sim card (the sim card which is not supported by Your phone) 2. The phone should ask for an unlock code 3. Enter Unfreeze or Defreeze code ( unsuccesfull message may appear ) 4. Enter NCK or Network code The phone is now unlocked If your phone does not ask for the unlock code: 1. Turn on the phone with original Sim card or without Sim card 2. Enter #7465625*638*NCK/Network# The phone is now unlocked. If your phone does not ask for the unlock code: 1. Turn on the phone with a foreign (Unaccepted) Sim card 2. Then enter the following sequence: #0199*Unfreeze/Defreeze# #0111*NCK/Network# #0121*SCK/Subprovider# #0133*SPCK/Provider# The phone is now unlocked. Watch recent video for Samsung C3590 Samsung i9000 Galaxy S unlocking simlock enter unlock codes - YouTube |
03-14-2014, 19:47 | #18 (permalink) | |
Junior Member Join Date: Mar 2014
Member: 2147876 Status: Offline Thanks Meter: 0 | Quote:
03-15-2014, 01:48 | #19 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | OK so your option is: If your phone does not ask for the unlock code: 1. Turn on the phone with original Sim card or without Sim card 2. Enter #7465625*638*NCK/Network# The phone is now unlocked. |
03-15-2014, 01:51 | #20 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | If your phone says the NET lock is ON then you need to do this without a sim inserted: #7465625*638*NCKCODE# or #SIMLOCK*NET*NCKCODE# If your phone says the SP lock is ON then you need to do this without a sim inserted: #7465625*77*SPCKCODE# or #SIMLOCK*SP*SPCKCODE# If your phone says the Subset lock is ON then you need to do this without a sim inserted: #7465625*782*SCKCODE# or #SIMLOCK*SUB*SCKCODE# |
09-27-2014, 21:57 | #22 (permalink) |
Freak Poster Join Date: Jul 2013 Location: CAPE VERDE
Member: 1973366 Status: Offline Sonork: 100.1646895 Thanks Meter: 42 | C3590 done wtih z3x Selected model: C3590 Selected port: COM98 SAMSUNG Mobile USB Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Preparing security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM97 Reading phone info... Model: GT-C3590 Country code: Open Factory SW: C3590XXMH2_OXAMH2 Unique number: 33373338233984 Memory phone: K521H12ACH(C3592)S Software version: C3590XXMH2/C3590OXAMH2 IMEI: 35678305135671 Bypass MSL... OK Reading codes... OK Please wait, calculating codes... OK (time - 00:01:00) PCK: NCK: 00000000 SCK: 00000000 SPCK: 00000000 MCK: 23248420 Done with Samsung Tool v.17.7 Selected model: C3590 Selected port: COM98 SAMSUNG Mobile USB Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Preparing security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM97 Reading phone info... Model: GT-C3590 Country code: Open Factory SW: C3590XXMH2_OXAMH2 Unique number: 33373338233984 Memory phone: K521H12ACH(C3592)S Software version: C3590XXMH2/C3590OXAMH2 IMEI: 35678305135671 Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.17.7 Done with Samsung Tool v.17.7 |
01-24-2015, 11:47 | #24 (permalink) | |
Freak Poster Join Date: Jan 2012 Location: kerala
Member: 1710992 Status: Offline Sonork: nibu Thanks Meter: 25 | 3590 unlocking done z3x box 100000000000000 % working well done Quote:
The Following User Says Thank You to nibukottayam For This Useful Post: |
08-29-2015, 13:40 | #25 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock Selected model: C3590 Selected port: COM67 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Preparing security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM391 Reading phone info... Model: GT-C3590 Country code: TSC Factory SW: C3590AEMH1_TSCMH2 Unique number: 24120000479006 Memory phone: K521H12ACH(C3592)S Software version: C3590AEMH1/C3590TSCMH2 IMEI: 351564073***** Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.18.9 Selected model: C3590 Selected port: COM67 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Preparing security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... not found Done with Samsung Tool v.18.9 Selected model: C3590 Selected port: COM67 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Preparing security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM391 Reading phone info... Model: GT-C3590 Country code: TSC Factory SW: C3590AEMH1_TSCMH2 Unique number: 24120000479006 Memory phone: K521H12ACH(C3592)S Software version: C3590AEMH1/C3590TSCMH2 IMEI: 351564073***** Bypass MSL... OK Reading codes... OK Please wait, calculating codes... OK (time - 00:00:00) PCK: 00000000 NCK: 00000000 SCK: 00000000 SPCK: 00000000 MCK: 00000000 Done with Samsung Tool v.18.9 BR |
09-18-2015, 23:53 | #26 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2460991 Status: Offline Thanks Meter: 0 | I've tried this but it doesn't quite work: after typing #0111* I get -------- as I enter in my NCK code which shows that it's accepting my NCK code. But when I type the final #, nothing happens. It still waits and accepts further input. Anyone know what's going on? Thanks, JMc |
07-30-2016, 19:02 | #27 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Macedonia
Member: 303652 Status: Offline Thanks Meter: 35 | After unlocking with z3x you must put this phrase: #0111*00000000# just eight time zero's! |
The Following User Says Thank You to kosturon For This Useful Post: |
