2G Latest Models Models made in 2011, 2012, 2013 year. |
12-20-2013, 16:00 | #33 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 852084 Status: Offline Sonork: paulboboby Thanks Meter: 5 | Selected model: C3560 Selected com port: COM7 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM400) Phone SN: RV1D97XBGS Deactivate MSL - OK Unlock - ok Elapsed time: 22 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- done by z3x thanks 2 z3x but we need support for samsung note 3 |
12-31-2013, 11:45 | #34 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1961509 Status: Offline Thanks Meter: 2 | C3590 done successfully using microbox Thanks for the help people who believe in giving: c3590 flip phone: use microbox phone: C3560 on test mode uart cable unlock enter code using: reading data: Msl active! 10:31:16 > bypassing msl [step1]: Ok! 10:31:17 > reading simlock data: Ok! 10:31:18 > checking server 1: Ok! 10:31:18 > connecting to server: Ok! 10:31:19 > asking server for access: Accepted! 10:31:19 > sending data to server: Ok! 10:31:45 > calculating [by server] please wait: Ok! 10:31:47 > disconnecting from server: Ok! 10:31:47 > mck code: #0199*00000000# 10:31:47 > nck code: #0111*55729460# 10:31:47 > spck code: #0133*00000000# 10:31:47 > sck code: #0121*20440520# 10:31:47 > pck code: #0141*00000000# 10:31:47 > phone code: 00000000 |
The Following User Says Thank You to fonextras2 For This Useful Post: |
01-15-2014, 08:42 | #35 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | C3590 unlock done z3x ------------------------------------------------------------------------------- Selected model: C3560 Selected com port: COM30 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM30) Deactivate MSL - fail Read info - fail Elapsed time: 5 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3560 Selected com port: COM30 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM30) Phone SN: RV1D94ECQG Deactivate MSL - OK Unlock - ok Elapsed time: 30 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
01-17-2014, 16:21 | #36 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK Age: 44
Member: 232341 Status: Offline Thanks Meter: 55 | Z3X DIRECT UNLOCK C3590 C3590ADMG1 CSC:3590O2UMG2 Selected model: C3560 Selected com port: COM6 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM113) Phone SN: RV1DB20Q7S Deactivate MSL - OK Unlock - ok Elapsed time: 22 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
01-20-2014, 16:28 | #37 (permalink) |
No Life Poster Join Date: May 2004 Location: UK Age: 52
Member: 86956 Status: Offline Thanks Meter: 104 | Confirmed. z3x - change settings to extended read codes , may fail on MSL first few times but then it'll go through and calculate - Selected c3560 on USB. |
01-20-2014, 18:24 | #38 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Kosova
Member: 87568 Status: Offline Thanks Meter: 101 | Selected model: C3560 Selected com port: COM11 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM381) Phone SN: RV1DC0H0YC Deactivate MSL - OK Calculated code please wait... Decrypted time: 43 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*97242730# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*55528400# this is Master(freeze) code |
01-29-2014, 22:22 | #39 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1423638 Status: Offline Thanks Meter: 12 | use microbox use cable t530k,c3300k phone must powered on 21:12:54 > BOX SN 21:12:54 > PORT: COM42 USB Serial Port SPEED: 115200 21:12:55 > SAMSUNG C3560 TEST MODE READ CODES: START! 21:13:14 > ACTIVATING TEST MODE: OK! 21:13:23 > READING IMEI: OK! 21:13:24 > READING SOFTWARE VERSION: OK! 21:13:26 > READING HARDWARE VERSION: OK! 21:13:27 > READING BLUETOOTH ADDRESS: OK! 21:13:29 > IMEI: 3567830 21:13:29 > VERSION: C3590AEMH1 21:13:29 > HARDWARE: MP 0.700 21:13:29 > MSL ADDRESS: RV1DB7MK6J 21:13:30 > BLUETOOTH ID: CC07AB-4E1F7A 21:13:31 > READING PHONE CODE: OK! 21:13:33 > READING DATA: MSL ACTIVE! 21:13:36 > BYPASSING MSL [STEP1]: OK! 21:13:40 > READING SIMLOCK DATA: OK! 21:13:41 > CHECKING SERVER 1: OK! 21:13:43 > CONNECTING TO SERVER: OK! 21:13:49 > ASKING SERVER FOR ACCESS: ACCEPTED! 21:13:51 > SENDING DATA TO SERVER: OK! 21:14:04 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 21:14:06 > DISCONNECTING FROM SERVER: OK! 21:14:06 > MCK CODE: #0199*00000000# 21:14:06 > NCK CODE: #0111*89816780# 21:14:07 > SPCK CODE: #0133*00000000# 21:14:07 > SCK CODE: #0121*18817350# 21:14:07 > PCK CODE: #0141*00000000# 21:14:07 > PHONE CODE: 00000000 21:14:11 > SAMSUNG C3560 TEST MODE READ CODES: END! insert sim caRD AND ENTER CODE |
04-07-2014, 11:19 | #42 (permalink) | |
Junior Member Join Date: Jun 2010
Member: 1333151 Status: Offline Thanks Meter: 1 | this solution worked 100% tesco uk Quote:
JOB DONE | |
04-23-2014, 11:35 | #44 (permalink) |
Freak Poster Join Date: Jan 2010 Location: UK
Member: 1212347 Status: Offline Thanks Meter: 16 | With me it failed few times but i closed software and launched again and in the first step without trying to unlock i selected the model C3560 as explained before by fellows, and then selected Extended read code and it failed once but while it was restarting i pressed read code again and it worked,so try doing it while the handset is restarting and it should be alright |
05-13-2014, 08:53 | #45 (permalink) |
Major Poster Join Date: Feb 2010
Member: 1242652 Status: Offline Sonork: mdobrais Thanks Meter: 9 | Selected model: C3590 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... OK Sending preloader... error Done with Samsung Tool v.17.4 Please help- not unlocked and not flashing,, thanx |
