2G Latest Models Models made in 2011, 2012, 2013 year. |
03-19-2013, 14:53 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: kuruman
Member: 646368 Status: Offline Thanks Meter: 113 | Solution Samsung E2220/e2222/c3322 flashing Error Flash Database loaded Waiting for board reset Device connected to port: 2 Err305-Error during read SCROM Version START available now Problem is drivers, Solution is:Go to C:drive-program files-samsung folder> uninstall all previously installed samsung drivers. Reboot. Install sunstone driver (found inside your flasher folder).Connect the phone in DFU mode.and inshallah it should work. |
The Following 2 Users Say Thank You to cheyn For This Useful Post: |
02-20-2015, 15:28 | #9 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Kampala,Uganda
Member: 2294589 Status: Offline Thanks Meter: 116 | E2222 failing after flashing is done and working well but its giving properties when i try to remove keypad lock . where is the problem ? and what should i do to remove |
03-30-2015, 09:43 | #10 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | i want to flash e2220 with z3x but error is that " sending loader failed """ plz give the solution of this problem ,,,,,, thanks in advance |
08-31-2015, 16:15 | #14 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1634909 Status: Offline Sonork: asifdosani Thanks Meter: 0 | i have purchased a new samsung c3322i but there is many more unwanted apps and games available. can i remove some unwanted apps and games from firmware of c3322i????? |
08-31-2015, 21:17 | #15 (permalink) |
Member: 646368 Status: Offline Thanks Meter: 113 | Sorry..all letters wrritten in yellow..it is not eligible to read in that colour..kindly change the colour of the fonts. |
The Following User Says Thank You to cheyn For This Useful Post: |
