11-23-2018, 04:25 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: ua
Member: 1001119 Status: Offline Sonork: 100.1601226 Thanks Meter: 129 | 5033t unlock error plz check it what problem。 This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [5]META Port Detected: MediaTek USB VCOM (Android) (COM5) USB\VID_0E8D&PID_2007\CUVKKVPNCUBQAMFA ChipID: MT6739,S01 Using Algo 5. Starting META using port[COM5], wait... BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R2.MP.V18.T5857 MODEM HW Version : TK_MD_L4_HW IMEI location: OTP IMEI[1] : 35XXXXXXXXXXXX IMEI[2] : 000000000000000 ERROR[1]:General error All done. |
01-14-2019, 15:44 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | To unlock this phone, need to use database from support. First user not readed help and update thread. From what i'am see, you have same problem. |
04-16-2019, 12:21 | #7 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am really not understand why need to ask again and again for this very simple thing. Anyway, let's explain once again. In settings tab, need to press access support. Access support will open support page, for this need to press this button. In opened web page, you will see many folders with different names, you must open folder named MTK Database files, Inside you will see Alcatel folder. You must open this folder, inside will be many files. You can find your file for your model and download it. After will need to extract downloaded arhive(we compress it to be sure about file integrity), you must have installed in your pc winrar, winzip, 7z or other compatible exe. After this need to load extracted file in exe. Don't try to load downloaded file without extracting, it will not work. Inside will not be 5033A,B,C,D,X,T so on files. Will be only 5033 in your case, we not added multiple files to save space, anyway is simple to understand this. I'am hope, i'am explained detailed step by step, and this will help you to access support and download database file for your phone. |
The Following User Says Thank You to orbita For This Useful Post: |
05-02-2019, 15:36 | #8 (permalink) | |
Freak Poster Join Date: Dec 2002 Location: Scotland
Member: 18535 Status: Offline Thanks Meter: 11 | Quote:
After downloading db file from support, job done! Thanks for the info I never realised there were so many file in the support section ! That will help me a lot in the futeure Thanks maxmix | |
