09-16-2017, 09:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 51
Member: 51545 Status: Offline Thanks Meter: 55 | Alcatel 2045x white screen after flash Code: 2045X_L6HU_V1.1_160219_CAM30_MCP128_64_FM_BT_HU_IZ 2045X_L5EN_V1.5_160107_CAM30_MCP128_32_FM_BT_HU_TELENOR After that I try flash with next firmwares: Code: 2045X_L1EN_V1.6_151019_CAM30_MCP128_64_FM_BT_UK_OB 2045X_L5MC_V1.8_150616_CAM30_MCP128_64_FM_BT_ME_TMOBILE 2045X_L5PL_V1.9_150714_CAM30_MCP128_64_FM_BT_PL_TMOBILE 2045X_L5RO_V1.3_160307_CAM30_MCP128_64_FM_BT_RO_VD 2045X_L5SP_V1.8_160111_CAM30_MCP128_64_FM_BT_ES_TL 2045X_L6SP_V2.2_151026_CAM30_MCP128_64_FM_BT_IBERIA 2045X-2XPWGB1_V2.2_161209_Original_Stock_ROM_by_bRkA Help me with normal firmware for new screen type, please. |
09-18-2017, 06:34 | #3 (permalink) |
Member: 51545 Status: Offline Thanks Meter: 55 | Here are logs: Boot Info: Code: EXE VERSION: NCKDongle MTK Tool 1.50 DA version: 5.1428.00.00 USER SELECTION : BOOT INFO. MODEL SELECTED : OT-2045X PHONE MUST BE OFF WITH BATTERY INSIDE. Connect phone in boot mode ... Com port ok : COM5 Phone detected...Please wait Download DA now...You can release power on CHANGE BAUDRATE SUCCES :S_DONE(0) DA download finished...Getting phone info BaseBand CPU: MT6276_S0101 BaseBand CPU Secure Version : FF FLASH TYPE : NAND ID: NAND:(1Gb) [TOSHIBA] TC58NYG0S8C size:0x08000000 INT RAM: 672Kb RAM: 512Mb DRAM BOOT STYLE :S_NAND_FLASH_BOOT(1034) NAND FAT Ranges = 0x03800000 length:0x04800000 Disconnecting phone :S_DONE(0) ALL DONE. Code: USB Connection selected. EXE VERSION: NCKDongle MTK Tool 1.50 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM5 Phone detected...Please wait Conected ok with target ... Reopen comport(COM5) BaseBand CPU : MT6276 SW_VER : 2045X_L5GR_V1.6_160712_CAM30_MCP128_64_FM_BT_IE_VD HW_VER : HW01 Meta mode conected ok, start reading phone.... Phone imei[1] : 3515300XXXXXXXX User code(Inactive) : 0000 SIMLOCK INFO[1]: Block1[N]: Locked (remain:5) Code : 94088870 Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked META END OK. Code: EXE VERSION: NCKDongle MTK Tool 1.49 DA version: 5.1428.00.00 USER SELECTION: WRITE FIRMWARE. MODEL SELECTED: OT-2045X PHONE MUST BE OFF WITH BATTERY INSIDE. Com port opened...Press power on Download DA now...You can release power on DA download finished...Getting phone info BaseBand CPU:MT6276_S0101 BaseBand CPU Secure Version : 5 (Secure baseband) INT RAM: 672Kb EXT RAM: 512Mb DRAM FLASH TYPE : NAND ID: NAND:(1Gb) Unnamed Flash size:0x08000000 CHANGE BAUDRATE SUCCES [3162]CBR Record not exist. FORMATING FLASH. ACTION FORMAT : NAND FLASH : BEGIN(0x03800000) - LEN(0x04800000). Format: Begin: 0x03800000 - Len: 0x04800000 Bad Blocks: 65390628 Error Blocks: 2 Total Blocks: 0 Bad/Error Block Ratio: (-0.000%) START DOWNLOAD FLASH. MAKE PREFLASH CONFIG, THIS CAN TAKE UP TO 1 MIN. Process bootloader now... ACTION : PROGRAMMING TARGET. Disconnecting phone :S_DONE(0) ALL DONE. |
09-18-2017, 07:13 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Your problem with white screen can he here Code: Bad Blocks: 65390628 Error Blocks: 2 Total Blocks: 0 Bad/Error Block Ratio: (-0.000%) |
09-18-2017, 07:27 | #5 (permalink) |
Member: 51545 Status: Offline Thanks Meter: 55 | Here are same stories with white screen. http://forum.gsmhosting.com/vbb/f272...oblem-2164783/ http://forum.gsmhosting.com/vbb/f272...creen-2205332/ http://forum.gsmhosting.com/vbb/12194893-post276.html Last edited by Doktor666; 09-18-2017 at 07:35. |
09-18-2017, 07:51 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Mistery is solved I'am uploaded in support pdf document Technical Note of model 2045 (Tiger XL 3G)LCD needs to match difference SW when repair.pdf Today will upload also all 2017 firmwares for this model. |
09-18-2017, 07:55 | #7 (permalink) |
Member: 51545 Status: Offline Thanks Meter: 55 | With this firmware I'am want to promote my friend here screen is OK. Here is log: Code: BaseBand CPU Secure Version : 5 (Secure baseband) INT RAM: 672Kb EXT RAM: 512Mb DRAM FLASH TYPE : NAND ID: NAND:(1Gb) Unnamed Flash size:0x08000000 CHANGE BAUDRATE SUCCES [3162]CBR Record not exist. FORMATING FLASH. ACTION FORMAT : NAND FLASH : BEGIN(0x00000000) - LEN(0x08000000). Format: Begin: 0x00000000 - Len: 0x08000000 Bad Blocks: 65420316 Error Blocks: 3 Total Blocks: 0 Bad/Error Block Ratio: (0.000%) START DOWNLOAD FLASH. MAKE PREFLASH CONFIG, THIS CAN TAKE UP TO 1 MIN. Process bootloader now... ACTION : PROGRAMMING TARGET. Disconnecting phone :S_DONE(0) ALL DONE. |
09-18-2017, 07:57 | #8 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Try to read my repply In support exist same firmware 2045X_L5EN_V1.6_160718_CAM30_MCP128_32_FM_BT_HU_TE LENOR.rar From where this guy downloaded firmware and put his name on it? Is really funny, i'am trying to help you and you only try to spam here. Thread closed. Last edited by orbita; 09-18-2017 at 08:02. |
