08-03-2018, 06:27 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 822589 Status: Offline Sonork: Mbo Thanks Meter: 18 | Alcatel 4033d flashing failed |
08-27-2018, 20:37 | #3 (permalink) | |
Member: 822589 Status: Offline Sonork: Mbo Thanks Meter: 18 | Quote:
Selected 0-By CPU:ELBRUS Exe version: NCKDongle AndroidMTK 2.5.9.2 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM6) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35585a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35585A4D42 : 00000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] High speed disabled by user, continue with this settings. Starting phone format, wait! FORMAT EMMC FLASH : BEGIN: 0x0 - LEN: 0xe9000000 Error FlashTool: S_FT_FORMAT_FAIL when i try to format this the result it is giving me Flash files count is :12 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKDongle AndroidMTK 2.5.9.2 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM6) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35585a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35585A4D42 : 00000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM Port (COM7) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... [4008]Error: S_FT_DOWNLOAD_FAIL this the result it is giving when i try to flash it | |
08-27-2018, 21:11 | #5 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You must first check your hardware. S_FT_FORMAT_FAIL and S_FT_DOWNLOAD_FAIL mostly meen hardware problem(flash ic is in read-only state). |
