02-08-2013, 10:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Canada Toronto
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | alcatel one touch 903 not unlock [SOLVED] Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. \\.\COM121 Error open meta port. Check drivers, phone battery if charged! Try again. All done.......... alcatel android driver not install ....use every file but driver not install |
02-08-2013, 15:27 | #3 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,265 | Drivers in support tested many times, and you must install manualy from device manager and use CDC drivers for unlocking. BR |
02-08-2013, 17:13 | #4 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
2.Wait untill phone power full. 3.When phone full power on, read codes from advansed meta. Try this please. | |
02-09-2013, 09:48 | #6 (permalink) |
No Life Poster Join Date: May 2012 Location: NCK Team
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | 've Got answers : 1. Install CDC drivers, it's important. 2. Open AndroidMTK module, select model, click service tab and boot phone in advansed meta. 3. Wait untill phone power full. 4. When phone full power on, read codes from advansed meta. Try this, and post result. br. |
02-09-2013, 12:16 | #7 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | Port detected : NCK Dongle USB Serial Port (COM121) \\.\COM121 Error open meta port. Check drivers, phone battery if charged! Try again. All done. same problem phone not start and hang |
02-09-2013, 14:09 | #11 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | It become funny. 2 Supporters and product manager say you how to solve problem and you continue. Driver marked with ! in device manager not say you nothing? It's ok from your side? Before make some try to understand what you do really. Will say once again, install drivers. If your pc not accept auto drivers instalation , install drivers manual. |
The Following User Says Thank You to orbita For This Useful Post: |
02-09-2013, 14:16 | #12 (permalink) |
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | @pak555 Just one question would be : Owned the knowledge of how to drivers properly installed your OS? |
The Following User Says Thank You to kaller1 For This Useful Post: |
