05-12-2013, 02:06 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Portugal Age: 48
Member: 4975 Status: Offline Thanks Meter: 612 | ...:: Download official Nokia firmware without Navifirm+ ::.. ...:: Download official Nokia firmware without Navifirm+ ::.. Things you need: 1. Latest version of Nokia Suite (version 2013_13_4_4) 2. usergroupsconfiguration.cfg file You can download both files from Here Installation: 1. First install Nokia Suite. Do not run after the installation is finished [IMG]http://www.****************/nokia/1.jpg[/IMG] 2. After Nokia Suite installs, copy and replace the usergroupsconfiguration.cfg file to C:\Program Files (x86)\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if you’re running a 64-bit version of Windows. Or C:\Program Files\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if on 32-bit. Running Nokia Suite and Downloading the firmware: 1. Open Nokia Suite. And select ‘Product Support Tool For Store 5.0′ [IMG]http://www.****************/nokia/2.jpg[/IMG] 2. When prompted, select ‘CareSuite External’ then hit ‘Sign-in’ button. [IMG]http://www.****************/nokia/3.jpg[/IMG] 3. From the Menu, select Tools, then ‘Firmware Download’ [IMG]http://www.****************/nokia/4.jpg[/IMG] 4. Now enter the product code of your device, hit ‘Check Online’ button, to check the latest firmware version of your product code. [IMG]http://www.****************/nokia/5.jpg[/IMG] 5. Then ‘tick’ ‘Optional Content Files and ‘Download’ to save your firmware. 6. Wait a few minutes for your files to download 7. You may now manually flash your Nokia device with the firmware you just downloaded. TIP: - Your firmware should be stored in the C:\ProgramData\Nokia\Packages\Products folder of your hard drive. - If you need to download a different firmware version for the same product code, I suggest you wait for your first download to finish, save all the downloaded files in a marked folder, then proceed with your next download. - Partial List of Nokia Lumia product codes. WARNING & DISCLAIMER: This process is for experimental purposes ONLY. I will not be responsible for any damage your device may incur during the manual flashing. PROCEED AT YOUR OWN RISK. |
The Following 16 Users Say Thank You to schwantz For This Useful Post: |
