04-17-2018, 22:38 | #1 (permalink) | ||
Freak Poster Join Date: Aug 2013 Location: E.U.A.
Member: 2000941 Status: Offline Sonork: 100.1612069 Thanks Meter: 72 | Help Please Aiwa AW790 FRP failed [ANSWERED] Quote:
05-08-2018, 20:03 | #8 (permalink) |
Freak Poster Join Date: Jan 2007 Location: tijuana mexico
Member: 424144 Status: Offline Thanks Meter: 78 | frp add please team log read meta info Action : Meta Info. Selected Model: 0-By CPU:MT6737T Exe version: NCKDongle AndroidMTK 2.5.8.9 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [3]Detected: MediaTek PreLoader USB VCOM (Android) (COM3) \\?\usb#vid_0e8d&pid_2000#7&e5def41&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [102]META Port Detected: MediaTek USB VCOM (Android) (COM102) USB\VID_0E8D&PID_2007\_ Start sync target, waiting responce..... ChipID: MT6737T,S01 Using Algo 2. Brand: AIWA Board: AW790 Model: AW790 Name: AW790 Release: AIWA_AW790_003R Version: 7.0 Mediatek Version: AIWA_AW790_003R Branch: alps-mp-n0.mp1 Platform: MT6737T Reading imei IMEI[1]: 864833039976815 IMEI[2]: 864833039976815 Modem Version: LR9.W1444.MD.LWTG.MP KON6737M_65_5dELWG_DSDS_COTSX All done. boot mode info Action : Boot Info. Selected 0-By CPU:MT6737T Exe version: NCKDongle AndroidMTK 2.5.8.9 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... First stage DA fail, aborting BBCHIP MT6737T [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware Boot Fail.!!!. All done. dump firmware info Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... First stage DA fail, aborting BBCHIP MT6737T [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware Boot Fail.!!!. All done. |
05-08-2018, 21:44 | #9 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In time rule not changed. Like before you must follow exe hint now also. And no, ram loader not exists in phone and is not posible to extract from phone. |
05-08-2018, 21:49 | #10 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Not need any box for make rsa sign. You can use even openssl for this. If you not have, only factory loader can be used. Last edited by orbita; 05-08-2018 at 22:31. | |
07-13-2018, 00:07 | #11 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1090629 Status: Offline Thanks Meter: 1 | Just hold on the button volume + before connect the phone and during the process Exe version: NCKDongle AndroidMTK 2.5.9.0 Selected model: MT6737T Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM57) Boot mode: Brom Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... [emmi]EMMC CID: 150100525831424d42 ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (233Gb+24576Mb) SAMSUNG 0x525831424d42 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 150100525831424D42 : 00000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x748800000 [29.133 GB] -Reading GPT Drive OK Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
The Following User Says Thank You to alegre11 For This Useful Post: |
