hisense F23 any help i have reset privacy but phone dead when i try to flash backup firmware but fail !!! pls help i need signed firmware <blockquote class="imgur-embed-pub" lang="en" data-id="a/Mep1EXV"><a href="//imgur.com/Mep1EXV"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> |
If not available i will upload direct link free for you but f23 have varients for upload correct file send any info or preloader details |
I sent file link in pm Download and check |
same probleme Flash files count is :14 Action : Firmware update. Selected Model: Hisense: F23 Exe version: NCKDongle AndroidMTK 2.5.9.2 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM33) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514531334d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 150100514531334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM34) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Send preloader... Error: Is not posible to write readed firmware in this phone. This phone will accept only factory signed firmware. Wait untill phone will start charging. All done. |
Try to read exe log, starting from this line. Error: Is not posible to write readed firmware in this phone. This phone will accept only factory signed firmware. Wait untill phone will start charging. If you not understand, try to use google translate. Also nckdongle will never kill phone on privacy reset, actually you are first user who saying this. Better tell us exactly what you do. |
sorry for my english i read firmware then use reset privacy then full flash ! after that phone dead !! pls help |
kamal_singla he is give me signed firmware but same probleme |
What you meen same problem? Explain please. |
phone still dead !! MediaTek PreLoader USB VCOM ... |
Need to use full flash to repair phone, not safe flash. |
kamal_singla thxxxxxxxxxxx phone alive again after flash your file phone back again without imei ! i repair imei with nck dongle all done .... thx nck thx kamal solved |
@kamal_singla, can i also have the file please |
Need File too please |
