Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Dongle
Old 09-18-2018, 16:17   #1 (permalink)
Member: 2541944
Thanks Meter: 23
hisense F23 any help
i have reset privacy but phone dead when i try to flash backup firmware but fail !!!
pls help i need signed firmware
<blockquote class="imgur-embed-pub" lang="en" data-id="a/Mep1EXV"><a href="//imgur.com/Mep1EXV"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Old 09-18-2018, 17:43   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 4,125
Did you check support area?
If not available i will upload direct link free for you
but f23 have varients for upload correct file send any info or preloader details
Old 09-18-2018, 17:55   #3 (permalink)
Member: 2541944
Thanks Meter: 23
ok bro this preloader ! pls help
https://www63.zippyshare.com/v/y2XcWZwI/file.html
Old 09-18-2018, 18:25   #4 (permalink)
Member: 2211790
Thanks Meter: 4,125
I sent file link in pm
Download and check
Old 09-18-2018, 19:13   #5 (permalink)
Member: 2541944
Thanks Meter: 23
same probleme
Flash files count is :14
Action : Firmware update.
Selected Model: Hisense: F23
Exe version: NCKDongle AndroidMTK 2.5.9.2
Scenario: [0]Safe Flash
Reinsert phone battery.
Battery must be charged.
Phone must be off with battery inside.
Please insert USB cable now...
Detected : MediaTek PreLoader USB VCOM (Android) (COM33)
Boot mode: Preloader
BBCHIP: 335 0 ca00
Using Algo 2.
Scatter file loaded, not need emmi.
Phone detected...Please wait
Sending DA agent, please wait...
BaseBand CPU :MT6737M
BaseBand CPU Secure Version : FF
BaseBand CPU Bootloader Version : 01
INT RAM: 128 KB SDRAM
EXT RAM: 2 GB DRAM
EMMC: (116Gb+16384Mb) SAMSUNG 0x514531334d42
EMMC FW VERSION: 0d:00:00:00:00:00:00:00
EMMC CID: 150100514531334D42 : 00000000000000
EMMC UA SIZE: 0x3a3e00000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0x3a4a00000 [14.572 GB]
Status: USB_HIGH_SPEED
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : MediaTek DA USB VCOM (Android) (COM34)
Warning, flashing preloader disabled!
If you change android version, preloader must be flashed.
Flash EMMC Algo Start.
Preloader backup already exist, skip saving.
Starting flash.
Send preloader...
Error: Is not posible to write readed firmware in this phone.
This phone will accept only factory signed firmware.
Wait untill phone will start charging.
All done.
Old 09-18-2018, 19:20   #6 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,324
Try to read exe log, starting from this line.
If you not understand, try to use google translate.
Also nckdongle will never kill phone on privacy reset, actually you are first user who saying this.
Better tell us exactly what you do.
The Following User Says Thank You to orbita For This Useful Post:
Old 09-18-2018, 19:30   #7 (permalink)
Member: 2541944
Thanks Meter: 23
sorry for my english i read firmware then use reset privacy then full flash ! after that phone dead !! pls help
Old 09-18-2018, 19:34   #8 (permalink)
Member: 2541944
Thanks Meter: 23
kamal_singla he is give me signed firmware but same probleme
Old 09-18-2018, 19:44   #9 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,324
What you meen same problem?
Explain please.
Old 09-18-2018, 20:15   #10 (permalink)
Member: 2541944
Thanks Meter: 23
phone still dead !! MediaTek PreLoader USB VCOM ...
Old 09-18-2018, 20:29   #11 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,324
Need to use full flash to repair phone, not safe flash.
Old 09-18-2018, 20:57   #12 (permalink)
Member: 2541944
Thanks Meter: 23
kamal_singla
thxxxxxxxxxxx phone alive again after flash your file phone back again without imei ! i repair imei with nck dongle all done .... thx nck thx kamal
solved
The Following User Says Thank You to disable-lock For This Useful Post:
Old 12-19-2018, 07:17   #13 (permalink)
Member: 2669746
Thanks Meter: 3
@kamal_singla, can i also have the file please
Old 12-03-2019, 21:02   #14 (permalink)
Member: 640636
Thanks Meter: 3
Need File too please
Page generated in 0.32431 seconds with 7 queries
