03-12-2013, 16:26 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | how to enter unlock code pantech wp8990vw?? [ANSWERED-SOLVED] how to enter unlock code pantech wp8990vw? there is a onfor but not understand please give me more detailed thanks. |
03-12-2013, 19:56 | #2 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | You may try it: Quote:
NCK Team | |
The Following 2 Users Say Thank You to NCKCDMA For This Useful Post: |
03-13-2013, 12:46 | #3 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | what is the Quote:
Thanks | |
03-13-2013, 18:36 | #4 (permalink) |
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Its last 4 digit of MDN (Your CDMA Mobile Number which people dial to call you). For example, +44029988776644332, then code is 4332. Br, NCK Team |
The Following User Says Thank You to NCKCDMA For This Useful Post: |
03-14-2013, 07:30 | #5 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
the phone came without sim card and I don't know how to check the cdma mobile number... Also customer is doesn't know the number. Is there any method to check number. Thanks. | |
03-14-2013, 07:47 | #6 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | yes i got the code steps menu contacts My Name Card (7) you will see the number like this 631-678-5163 So the code is 5163 Thanks for all. I Unlocked the phone. Also when you select the CDMA Mode when enter to screen ( MANU) you can not change the GSM mode So you want to unlock first using the selection of CDMA mode . After unlock the follow the step above to change to GSM mode.Then you will have the signal. Thanks. |
The Following User Says Thank You to sky_finder For This Useful Post: |
03-14-2013, 07:51 | #7 (permalink) | ||
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Quote:
NCK Team | ||
