04-17-2013, 12:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2010 Location: romania
Member: 1390461 Status: Offline Thanks Meter: 80 | htc desire c unlock problem [ANSWERED - SOLVED] i connected rhe phone in bootloader mode,run cmd, typed fastboot oem get_identifier_token,but the window with the info closes after a second. i got all the right drivers,good cable but still this problem.any solution? |
04-17-2013, 12:35 | #2 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | Quote:
http://forum.gsmhosting.com/vbb/f691...ire-c-1601059/ | |
04-17-2013, 13:54 | #3 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | ok,i follow these steps firs time and i got the issue with the cmd screen dissappear.i registered on the site,all good,enter phone in bootloder mode,typed cmd command and when i got the info,the cmd shuts down and i can`t see anything |
04-17-2013, 14:12 | #4 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Romania Age: 46
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | @upgraderazvan use vivid shell to get identifier . Dev-Host - Vivid_All-In-One_Kit_v2.2.rar - The Ultimate Free File Hosting / File Sharing Service br. |
04-17-2013, 14:20 | #5 (permalink) | |
Member: 1390461 Status: Offline Thanks Meter: 80 | Quote:
,,deja am incercat,nu suporta modelul,,ai alta sugestie? allready tryed,unnsuported phone.any other sugestion? | |
04-17-2013, 14:39 | #6 (permalink) |
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | redirecteaza iesirea catre un fisier text redirect the output to a text file in command prompt type fastboot oem get_identifier_token >test.txt rezultatul ar trebui sa fie in fisierul text the result should be in the text file br. |
04-17-2013, 14:40 | #7 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | ok,extracted the token with the attached tool ,revived unlock_code.bin,pasted to htc directory like instructed,and run the second_step but all i get is this C:\NCK Dongle\NCK Dongle HTC Android Tool\Root_HTC_desire_C>echo you must put fi le unlocked.bin in same directory you must put file unlocked.bin in same directory C:\NCK Dongle\NCK Dongle HTC Android Tool\Root_HTC_desire_C>fastboot.exe flash u nlocktoken Unlock_code.bin sending 'unlocktoken' (0 KB)... |
04-17-2013, 14:58 | #9 (permalink) |
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | copy Unlock_code.bin in same folder with fastboot.exe pune telefonul in fastboot put the phone in fastboot then in command prompt fastboot flash unlocktoken Unlock_code.bin br. |
04-17-2013, 15:42 | #10 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | C:\Documents and Settings\io.IO-501C4FFF54DC\My Documents\Downloads\Vivid_All-In -One_Kit_v2.2\data>adb kill-server C:\Documents and Settings\io.IO-501C4FFF54DC\My Documents\Downloads\Vivid_All-In -One_Kit_v2.2\data>adb reboot bootloader * daemon not running. starting it now on port 5037 * * daemon started successfully * error: device not found C:\Documents and Settings\io.IO-501C4FFF54DC\My Documents\Downloads\Vivid_All-In -One_Kit_v2.2\data>fastboot flash unlocktoken Unlock_code.bin sending 'unlocktoken' (0 KB)... INFOstart check_usb: usb_ep0: type=128, reques t=6 i think probl with comunuication |
04-17-2013, 16:04 | #11 (permalink) | |
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | Quote:
pune telefonul in fastboot ,cu volum jos si power ,selecteaza fastboot si conecteaza telefonul la usb ;in command prompt scrie : fastboot flash unlocktoken Unlock_code.bin br. | |
The Following User Says Thank You to timiG For This Useful Post: |
04-17-2013, 19:21 | #13 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | htc hodule says not rooted after root done! htc desire c -unlocked bootloader succesfuly -rooted phone with this tutorial How to Root HTC Desire C Android 4.0 ICS with Superboot -open htc module,select htc desire c MODEL 1: Desire C MODEL 2: HTC Desire C / golfu OS VERSION: ANDROID 4.0.3 IML74K FIRMWARE: 2.00.401.2 / 10.11.98.09H_1.06.98.13M2 IMEI: 3543790xxxxxxxxx BOOTLOADER: 1.28.0000 HTC HWID: golfu-1 KERNEL VERSION: 3.0.16-g51cada9 HTC CID: HTC__032 HTC MID: PL0110000 CpuInfo: ARMv7 Verifying root Not rooted You need root your phone first, complet guide and file located in "Root HTC desire C" directory. Log saved to : C:\NCK Dongle\NCK Dongle HTC Android Tool\logs\HTC_DESIRE_C_log23.txt solutin anybody?is very urgent!thx!!!! |
04-17-2013, 19:22 | #14 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | htc module says not rooted after root done!!!!!htc desire c [SOLVED] htc desire c -unlocked bootloader succesfuly -rooted phone with this tutorial How to Root HTC Desire C Android 4.0 ICS with Superboot -open htc module,select htc desire c MODEL 1: Desire C MODEL 2: HTC Desire C / golfu OS VERSION: ANDROID 4.0.3 IML74K FIRMWARE: 2.00.401.2 / 10.11.98.09H_1.06.98.13M2 IMEI: 3543790xxxxxxxxx BOOTLOADER: 1.28.0000 HTC HWID: golfu-1 KERNEL VERSION: 3.0.16-g51cada9 HTC CID: HTC__032 HTC MID: PL0110000 CpuInfo: ARMv7 Verifying root Not rooted You need root your phone first, complet guide and file located in "Root HTC desire C" directory. Log saved to : C:\NCK Dongle\NCK Dongle HTC Android Tool\logs\HTC_DESIRE_C_log23.txt solutin anybody?is very urgent!thx!!!! |
04-17-2013, 21:46 | #15 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | SOLVED USED THE ROOT FROM SUPORT AREA AND ALL GOOD NOW MODEL 1: Desire C MODEL 2: HTC Desire C / golfu OS VERSION: ANDROID 4.0.3 IML74K FIRMWARE: 2.00.401.2 / 10.11.98.09H_1.06.98.13M2 IMEI: 3543790XXXXXXXXXXXX BOOTLOADER: 1.28.0000 HTC HWID: golfu-1 SDCARDID: 0353445355303147800E65247000B4CA KERNEL VERSION: 3.0.16-g0be4e84 HTC CID: HTC__032 HTC MID: PL0110000 CpuInfo: ARMv7 Verifying root Root ok Unlocking Plz wait... calculating codes plz wait... Simlock Status : Locked. Network Code : 15365745 Unlock Done. Log saved to : C:\NCK Dongle\NCK Dongle HTC Android Tool\logs\HTC_DESIRE_C_log35.txt THX NCK TEAM! |
The Following 2 Users Say Thank You to upgraderazvan For This Useful Post: |
