Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 10-26-2018, 03:34   #1 (permalink)
Member: 2429925
Thanks Meter: 17
alcatel 5059a error
Exe version: NCKDongle AndroidMTK 2.5.9.5
Selected model: Alcatel OT-5059A
Action: Unlock
Will be used database connection.
Scanning for presents meta ports...
Phone must be off with battery inside.
Please insert USB cable now...
In some phones need to keep VOL- button untill inserting USB cable.
[20]Detected: MediaTek USB Port (COM20)
\\?\usb#vid_0e8d&pid_0003#5&241a019b&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Starting META mode, wait...
[178d]Error: S_SECURITY_SEND_AUTH_FAIL
All done.
any solutions
Old 11-19-2018, 20:18   #2 (permalink)
Member: 200321
Thanks Meter: 2
Same problem. Anyone help us.
Thanks a lot.
Old 11-20-2018, 07:38   #3 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Contact me by skype with phone in hands.
Old 11-20-2018, 21:43   #4 (permalink)
Member: 200321
Thanks Meter: 2
Thanks a lot. Is done.
Have a good day!
Old 11-21-2018, 08:25   #5 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Will help another users if you will explain where was the problem.
The Following User Says Thank You to orbita For This Useful Post:
Old 11-21-2018, 19:24   #6 (permalink)
Member: 2394050
Thanks Meter: 47
Have a good day!
hello, please you can shared your solution?
The Following User Says Thank You to alexdroidcuba For This Useful Post:
Old 05-29-2019, 12:54   #7 (permalink)
Member: 2702045
solved alctael ot-5099Y unlock
before i have got error then i find solution my self here is full log
Exe version: NCKDongle AndroidMTK 2.5.9.9
Selected model: Alcatel OT-5059Y
[61]Detected: MTK USB Port (COM61)
\\?\usb#vid_0e8d&pid_0003#6&3999aca5&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Error open meta port[COM0].
[0]All done.
step by step
1. select flash mode
2. tick force detect brom
3.tick force detect preloader
4.enable high speed port
click on unlock button and connect powerd off phone to usb and wait
unlock will done
after
Selected model: Alcatel OT-5099Y
Reinsert phone battery.
Battery must be charged.
Detected : MTK USB Port (COM61)
Boot mode: Brom
BBCHIP: 321 0 ca00
Using Algo 2.
Phone detected...Please wait
Sending DA agent, please wait...
BaseBand CPU :MT6737T
BaseBand CPU Secure Version : 05
BaseBand CPU Bootloader Version : FE
INT RAM: 128 KB SDRAM
EXT RAM: 2 GB DRAM
EMMC: (116Gb+16384Mb) SAMSUNG 0x514536334d42
EMMC FW VERSION: 03:00:00:00:00:00:00:00
EMMC CID: 150100514536334D42 : 00000000000000
EMMC UA SIZE: 0x3a3e00000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0x3a4a00000 [14.572 GB]
Status: USB_FULL_SPEED
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : MediaTek DA USB VCOM Port (COM63)
Phone have OTP partition.
MODEL FROM PROINFO: 5099Y-2CTWGB1
SECRO FROM PROINFO: X6J0CT02CK20
OTP IMEI: 353937090432465
Reading security, wait...
SIM[1]:
Block1(N): Unlocked (remain:10)
Block2(NS): Unlocked
Block3(SP): Unlocked
Block4(C): Unlocked
SIM[2]:
Block1(N): Unlocked (remain:0)
Block4(C): Unlocked
Wait untill phone will start charging.
[0]All done.
The Following User Says Thank You to rider79 For This Useful Post:
Page generated in 0.16359 seconds with 8 queries
