Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Dongle
Old 03-25-2019, 13:47   #1 (permalink)
Member: 380870
Thanks Meter: 112
Exclamation Huawei CLT-AL00 HUAWEI ID
Hy NCK team. i try to remove Huawei ID from CLT-AL00 P20 pro and i recive this.
OEM File to update: CLT-AL00
3/25/2019 14:37:27 Starting to write device...
Waiting for fastboot device...
Device found: D5F7N18C25001614
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN5F7N18C25001614
IMEI:8655630XXXXXXXX
IMEI1:8655630XXXXXXXX
MEID:A000009E659F4B
Build number: :CLT-AL00 8.1.0.176(C00)
Model: CLT-AL00
Battery state: 5967mv
OEM lock state info:
FB LockState: LOCKED
USER LockState: LOCKED
OEM get bootinfo:
locked
Writing OEMINFO partition
OEMINFO partition UPDATE :FAIL Command not allowed
Update fastboot mode failed
3/25/2019 14:37:41 Writing device finished - INCOMPLETE.\
Any solution. Thanks in advance
Old 03-25-2019, 14:24   #2 (permalink)
Member: 380870
Thanks Meter: 112
p20 pro huawei id
after select the bootloader and oeminfo it flash ok on usb 1.0 mode but huawei id stiil remains
Old 03-25-2019, 16:44   #3 (permalink)
Member: 380870
Thanks Meter: 112
I manage to flash bootloader and oeminfo crom ctl-l29. Now the phone bypass huawei id and is possible to enter menu. My question is: how i delete permanent old huawei id??
Sent from my SM-N960F using Tapatalk
The Following User Says Thank You to zoltar1308 For This Useful Post:
Old 04-09-2019, 17:43   #4 (permalink)
Member: 78516
Thanks Meter: 53
Hi can you give how did you do ?
thanks
Old 04-09-2019, 19:26   #5 (permalink)
Member: 380870
Thanks Meter: 112
thanks
Hy. I make tp on board and flash bootloader and oeminfo from CLT-L29 and phone boot direct in menu. After i falsh update.app with another tool and phone boot normally and make factory reset and no huawei id.
Old 04-15-2019, 14:31   #6 (permalink)
Member: 18006
Hi Zoltar, you can help me to do ? I have same problem, i need to remove huawei id from clt-a00
thanks
Old 04-15-2019, 14:41   #7 (permalink)
Member: 380870
Thanks Meter: 112
Read my post upper
Sent from my SM-G975F using Tapatalk
Old 04-15-2019, 14:43   #8 (permalink)
Member: 18006
i don't now were tp is
Old 04-15-2019, 15:05   #9 (permalink)
Member: 18006
i don't know were are tp on board, and how to flash
Old 04-15-2019, 15:17   #10 (permalink)
Member: 380870
Thanks Meter: 112
I send you pm.
Old 04-15-2019, 15:19   #11 (permalink)
Member: 18006
thanks, waiting for pm
Page generated in 0.51214 seconds with 7 queries
