01-26-2018, 09:50 | #2 (permalink) |
Freak Poster Join Date: Apr 2014 Location: Mostly on Skype :)
Member: 2161887 Status: Offline Sonork: 100.1605383 Thanks Meter: 193 | kindly don't mind before posting any thing first google it if you are not able to find any thing then post in details about what you are trying to do with logs here is success report for same model http://forum.gsmhosting.com/vbb/f826...eport-2192702/ |
01-26-2018, 21:52 | #3 (permalink) |
Crazy Poster Join Date: Mar 2014
Member: 2154508 Status: Offline Sonork: javier-86 Thanks Meter: 9 | sr!!! Sr: I saw that report and it came out successful, but I do not mount the boot and the cell phone if you mount the com port on the PC and install the drivers and everything but the software does not recognize it and they were different versions of the software the report was with the v0.4 and I'm using v0.5, sometimes when the boxes or dongles update can come up with new software errors with tasks and solutions that were already successful. Thank you |
01-26-2018, 23:18 | #5 (permalink) |
Member: 2154508 Status: Offline Sonork: javier-86 Thanks Meter: 9 | Sr!!! Well here are several points to reflect: 1- This Blu Z3 M cell says "SIM INVALID" does not ask for such unlock code. 2- the driver that mounts me and fixed in the reports is "SCI USB2Serial" and this cell that mounts me is fine is "SPRD U2S Diag" when I try to force SCI USB2Serial which is the driver that must mount the NCK dongle the boot gives me error in the drivers in device manager ... Thank you very much and awaiting your response ... on this subject! |
01-27-2018, 23:17 | #10 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Bro, you do wrong. Need to do in this way. 1.Remove phone battery. 2.Insert usb cable in phone and pc. 3.Press on exe button and when exe prompt keep boot key and insert battery. |
01-27-2018, 23:53 | #11 (permalink) |
Member: 2154508 Status: Offline Sonork: javier-86 Thanks Meter: 9 | no broth does not mount anything what it does is turn on my cell phone normally: If you look at this log, the friend says how to do it and that is how the only port is "SPRD U2S Diag", which in the previous comments tells me that the port has nothing to do with this port According to the mounts is this "SCI USB2Serial" and it does not match the one that mounts this cell, but one aspect to keep in mind is that in the successful logs the cell phone asks for this cell code does not ask for code says "invalid SIM" successful log -- open NckBox Spreadtrum Module ---- then we select SC6531. ---- select in jod remove sim lock give jod with the cell without battery we press * 0 # we put the battery and the box will recognize the cell and just wait for the unlocking EXE: NckBox Spreadtrum Module 0.4 SELECTED : SC6531 ACTION: Unlock. SCENARIO: SC6531. Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press boot key while inserting the battery. Keep key untill boot complete. Detected: SCI USB2Serial (COM107) Sending loader, keep boot key untill loader start. Loader OK: nckTeam(2016) Beta 0.3 CPU: 6531 FlashId: WINBOND: [0x400000]W25Q32FV Reading Flash Info, wait... Flash Size: $400000 Sector Size: $8000 NVRAM Status: NV_MINVALID_SOK Checking nvram, wait.... Using mode 1 Writing simlock, wait... Write Done. Backup saved: backup\spd_nvram_backup\SC6531_359922071876843_sav ed_nv_1.bin Total Time: 00:00:19 Done. any other suggestions please Thank you. |
