07-19-2019, 19:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | Itel it2180(Movitel) flash fail phone was ok but needed network unlock i thought resef phoneefs could remove the simlock but then phone not boot after reset phone efs lucky i first made backup before any operation but then after write fullflash phone not boot. So i looked for a pac file to flash it since the backup could not work. flash sucess but display white. phone boot ok calls can recieve but display same. tried writing nv backup still same white screen. write again dump phone not power on. anyway to fix the white screen. display was ok before this. EXE: NckDongle Spreadtrum Module 0.9 SELECTED: SC6531EFM ACTION: Write FullFlash Flash ID: [EF4016] WINBOND: [0x400000]W25Q32FV size: 0x400000 Start Detect phone... Detected: SPRD U2S Diag (COM56) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. Send Second Loader. Writing nvram: begin: 0x3B8000 size: 0x6BE4 Write Done. Writing stone: begin: 0x0 size: 0x369EA4 Start write file: C:\Users\DamArt\Documents\spreadtrum_module\backup \spd_fullflash\SC6531EFM_W25Q32FV_89835777855705_s aved_full_.bin Total Time: 00:00:49 Done. EXE: NckDongle Spreadtrum Module 0.9 SELECTED: SC6531EFM ACTION: Restore NVRAM Start Detect phone... Detected: SPRD U2S Diag (COM56) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. Send Second Loader. Start write: C:\Users\DamArt\Documents\spreadtrum_module\backup \spd_nvram_backup\SC6531EFM_W25Q32FV_3576710721006 77_89835777855705_saved_nv_.bin Write Done. Total Time: 00:00:27 Done. |
07-20-2019, 08:56 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am told many times about need to use reset phone in diagnostic mode, also in new version is removed format efs in flash mode. On some models it cause problem and based on users report we removed this from exe. In diagnostic mode reset is safe without risk and this function exeists in exe from very long time. But no, some users will download and will use old version, and after we come here. White screen, meen your pac is not compatible with your phone. |
07-22-2019, 08:50 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In some phones brands change game rule Is introduced firmware sign like in mtk, to force to use factory firmware. Send me readed backup + pac file what you writed in phone, will try to help you. |
07-23-2019, 06:41 | #7 (permalink) | |
Member: 2541648 Status: Offline Thanks Meter: 166 | Quote: EXE: NckDongle Spreadtrum Module 0.9 ACTION: Flash Firmware. Selected firmware: it2180_saved_pac.pac Detecting device storage... Device Storage: NOR Detected: SPRD U2S Diag (COM13) [00:00:00] Sending loader. BOOT: SPRD3W Sending loader, keep boot key untill loader start. [00:00:00] Loader ok [00:00:00] Wait for loader.... Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. [00:00:01] First boot done. [00:00:01] Sending second loader. [00:00:01] Second loader sent ok. [00:00:01] Making NV backup. IMEI: 357671072100677 Backup saved: C:\Users\DamArt\Documents\spreadtrum_module\backup \spd_nvram_backup\357671072100677_saved_nv__3.bin [00:00:01] Start write: NV IMEI 1: 357671072100677 IMEI 2: 357671072100685 [00:00:01] Start write NV [00:00:02] Start write: SC6531EFM_G185C_it2180_32X32_128X160BAR_EnFrPoArSw Ha_stone.bin [A4][8] Error send frame. [CODE]Error Write: PS ,aborting. Error while writing firmware, aborting. Log saved: C:\Users\DamArt\Documents\spreadtrum_module\Saved_ Logs\357671072100677_writepac__3.txt Total Time: 00:00:33 Done. now working this pac, phone not power on | |
