06-28-2015, 06:34 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: hole
Member: 1784040 Status: Offline Thanks Meter: 32 | Lenovo a369i IMEI write HELP! [ANSWERED] |
06-28-2015, 06:51 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | You may try writing IMEI again in Flash Mode (Connection Mode - Flash Connection). Also try to Reset Phone. Br, NCK Team |
The Following User Says Thank You to NCKCDMA For This Useful Post: |
06-28-2015, 08:19 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | @sharthy12 When you connect in meta , phone show imei? Simlock can be readed? Imei can be damaged also from another reason. Press big help button for more info. Last edited by orbita; 06-28-2015 at 08:35. |
06-28-2015, 08:38 | #4 (permalink) | |
Member: 1784040 Status: Offline Thanks Meter: 32 | Quote:
Detected : PreLoader USB VCOM Port (COM16) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6572_S00 EMMC: (29Gb+4096Mb) SAMSUNG 0x4e355530304d EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 1501004E355530304D02A55E88F5A097 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : DA USB VCOM Port (COM18) Dumping NVRAM IMEI[1] TO UPDATE: 862775025002829 IMEI[1] from NVRAM: 862775025002829 IMEI[2] from NVRAM: 863713020262824 Calculated Checksum : 0xf9872db2 To activate imei need to perform wipe or Clear EMMC from factory mode. Wait untill phone will start charging. All done. already wipe and clear emmc but still invalid imei | |
06-28-2015, 08:53 | #7 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Instead of posting stupid recomendatios, try to understand first how mediateck phones work. After flashing will be same problem, invalid imei. So we will have lost time for nothing and same problem. Another sugestion? @sharthy12 if you want to solve your phone, read my repply. If not, you can try all sugestion, in final we will come back to initial step. |
06-28-2015, 09:01 | #9 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In main (first tab) exist one big button "HELP" Anyway, try to read codes in meta mode. If imei show ok and will give simlock error, you have damaged protect partitions. In this phone, this partition not reconstruct after flashing. If will be like i'am guess, need to read from some working phone security backup and write in your. |
The Following User Says Thank You to orbita For This Useful Post: |
11-06-2015, 23:57 | #10 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAŅA
Member: 808967 Status: Offline Thanks Meter: 155 | team try to repair imei but never ends well ca, because bia IMEI IMEI always origuinal Selected connection metod: Flash Connection Exe version: NCKDongle AndroidMTK 2.5.6.0 Selected phone: Lenovo A369I Action : IMEI REPAIR. IMEI for write : 865022067657146 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM11) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x4e35585a4d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004E35585A4D : 0000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM114) Dumping NVRAM IMEI[1] TO UPDATE: 865022067657146 IMEI[1] from NVRAM: 865022067657146 IMEI[2] from NVRAM: 865022027657145 Calculated Checksum : 0xf6fcda18 To activate imei need to perform wipe or Clear EMMC from factory mode. Wait untill phone will start charging. All done. |
11-07-2015, 06:09 | #11 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,339 | Quote:
To activate imei need to perform wipe or Clear EMMC from factory mode. | |
11-11-2015, 05:32 | #15 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You need to write security backup from another phone and imei will come back. If you not do this, imei will not be repaired. in help is explained about. |
