05-28-2018, 19:20 | #47 (permalink) |
Freak Poster Join Date: May 2008 Location: pakistan
Member: 774443 Status: Offline Sonork: 100.1603978 Thanks Meter: 41 | avainger box HUAWEI LUA-U22 FLASH PROBLEM Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM19) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... First stage DA fail, aborting BBCHIP MT6582 [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware Boot Fail.!!!. All done. |
05-28-2018, 20:24 | #49 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Next time post please full exe log. Posible you save forum space, but few more lines will not be a problem, and for us will be more simple to provide you help. | |
05-29-2018, 10:58 | #51 (permalink) | |
06-06-2018, 17:03 | #58 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Online Thanks Meter: 2,769 | please add full support for write firmware on v8.x.x in next update Flash files count is :16 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKDongle AndroidMTK 2.5.9.0 Scenario: [1]Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM21) Boot mode: Preloader Using Algo 1. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x464e36324d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 150100464E36324D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM Port (COM25) Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x79000000 - LEN: 0x7000000 FORMAT EMMC FLASH : BEGIN: 0x80000000 - LEN: 0x150f80000 [1003]Error: S_INVALID_BBCHIP_TYPE Wait untill phone will start charging. |
06-07-2018, 07:31 | #59 (permalink) | |
06-07-2018, 10:06 | #60 (permalink) |
Member: 1677653 Status: Online Thanks Meter: 2,769 | It from the same phone with same variety, only on NCK & umt not flash but flash done with other tool without any error, meanwhile I used NCK to backup firmware from working device... |
