Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 06-07-2018, 11:05   #61 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Originally Posted by Yusuf Lawal View Post
It from the same phone with same variety, only on NCK & umt not flash but flash done with other tool without any error, meanwhile I used NCK to backup firmware from working device...
I'am just gived you posible sugestion to solve problem.
It's up to you if you want to follow or not.
More, you can make debug log and check yourself where exactly where is problem.
And yes, to avoid posible phone killing, in nck is introduced more strict check for all this.
Was many time problem, when users in hurry flashed firmware from another phone and after ....was problem.
Debug log also will allow you to see exactly where is problem and fix it.
Old 06-15-2018, 00:23   #62 (permalink)
Ahmadaim1's Avatar
Member: 2165294
Thanks Meter: 59
Originally Posted by i.anas View Post
NCK Dongle Android MTK Module v2.5.9.0 Not found in support area
kindly give download link
Link doesn't work pls do something
Sent from my Infinix X559C using Tapatalk
Old 06-19-2018, 15:40   #63 (permalink)
Member: 1677653
Thanks Meter: 2,769
Download below file and extract in one folder then shortcut to desktop and run.. That is all...
Download Area
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 07-12-2018, 22:38   #64 (permalink)
Member: 185279
Thanks Meter: 43
Question
Same problem here:
[1003]Error: S_INVALID_BBCHIP_TYPE
I backup flash & dont can restore it, is from the same phone.
FlashTool_Download_Internal(): platform mismatch(BBChip type):PC load <->target("MT6752" <> "MT6580 " )
My phone is MT6580 & Backup is MT6580.
Old 07-13-2018, 11:28   #65 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Many clone firmware builders put in preloader not real name.
This start to happen from some time, is not old problem.
In next update this problem will be fixed, will be readed bb chip name acording with phone report.
Right now you can modify scatter manually and put pltform: MT6580 instead of platform: MT6752
Old 07-13-2018, 21:41   #66 (permalink)
Member: 2601431
Thanks Meter: 35
Originally Posted by Vero View Post
Same problem here:
I had the same problem and the solution was to flash all the partitions (I always uncheck the pre-loader box in the scatter file before hit flash).
Flash it all and write back the result.
Page generated in 0.17864 seconds with 8 queries
