please add repair up to 4 imei for spd and mtk phones |
Itel 1516 plus prp removed successfuly EXE: NckDongle Spreadtrum Module 0.4 SELECTED: SC7720EA_EMMC 5.x ACTION: Reset FRP Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SCI USB2Serial (COM78) BOOT: SPRD3 Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. Reading extended info, wait... FileSystem: EMMC Manufacturer: itel Hardware: SP7720EA_V1.0.0 Platform: sc8830 Build Id: LMY47D Model: itel it1516 Plus Android Release: 5.1 Android Version: LMY47D release-keys IMEI 1: 351674085264601 IMEI 2: 351674085264619 [USER]Simlock Status: UNLOCKED Simlock Type: 0 Removing frp, wait... Format OK. Total Time: 00:00:30 Done. TEAM add more SPD New boots in the next update. |
https://s23.postimg.org/vv9a5te2j/Untitled.png where can i find this boot or what boot do i select to choose that number in circle :confused: |
Now read more carefully page from you maked screenshot. In update is about diag mode, not about flash mode. So just a hint, you must use diag mode tab, not flash mode tab ?.:confused: example SC6820 - Read SimLock Unlock Codes in DIAG Mode - World's First (For Non Hardlocked Phones, sure phone must be locked to read code). |
ITEL 1556 PLUS Format UserData/frp EXE: NckDongle Spreadtrum Module 0.4 SELECTED: SC7720EA_EMMC 5.x ACTION: Format UserData Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SCI USB2Serial (COM30) BOOT: SPRD3 Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. Reading extended info, wait... FileSystem: EMMC Manufacturer: itel Hardware: SP7720EA_V1.0.0 Platform: sc8830 Build Id: LMY47D Model: itel it1556 Plus Android Release: 5.1 Android Version: LMY47D release-keys IMEI 1: 352849084629041 IMEI 2: 352849084629058 [USER]Simlock Status: UNLOCKED Simlock Type: 0 Formating userdata, wait... Formating cache, wait... [misc]Format OK. Total Time: 00:00:44 Done. EXE: NckDongle Spreadtrum Module 0.4 SELECTED: SC7720EA_EMMC 5.x ACTION: Reset FRP Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SCI USB2Serial (COM30) BOOT: SPRD3 Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. Reading extended info, wait... FileSystem: EMMC Manufacturer: itel Hardware: SP7720EA_V1.0.0 Platform: sc8830 Build Id: LMY47D Model: itel it1556 Plus Android Release: 5.1 Android Version: LMY47D release-keys IMEI 1: 352849084629041 IMEI 2: 352849084629058 [USER]Simlock Status: UNLOCKED Simlock Type: 0 Removing frp, wait... Format OK. Total Time: 00:00:21 Done. |
NCK Team we need more update for sprd module. Add spd cpu 6820/8810 full support read and write pac files. Also activate other spd cpus read and write pac files as well. |
Help SPRD MODULE V0.4 cant open after successfully activated 1 year support http://www.mediafire.com/convkey/4da...3cnrfm0pzg.jpg That is the message i get when i open the software but there is no upgrade in the Main Module |
Uninstall and download it again Sent from my SM-G532G using Tapatalk |
also all modules work correct except SPRD Module |
Will not be any fix here to allow you to use wrong version of exe. |
is there any solution to the above problem? i recently purchased my dongle but the spd module wont run please help |
