Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Dongle
Old 02-01-2019, 16:21   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 72,120
NCK Dongle / NCK PRO Spreadtrum Module v0.7 Update Released - [01/02/2019]
1. Added Basic support for SC6531EFM
- Supported Repair IMEI
-- Factory Reset
--- Read & Write NVRam
---- Write PAC File.
2. Added 2 Methods to service Phones in DIAG Mode.
- Old Method allow only to:
-- Read info (SimLock)/Reset phone/Repair IMEI/BT/Wifi
- New Method allow also to:
-- Perform Direct unlock in diag mode.
--- Usually new method work on phones with android 5.1 and more new.
---- It work also on SC6531EFM, possible on other generic phones too.
3. Added support for Simlock types 2,3,5 and 6 in DIAG Mode.
- For this types will be displayed sim unlock code on read info, and new phones will allow direct unlock.
-- For other types will need Simlock backup and link to phone firmware.
3. Remade PAC files Writer.
-- Now it become more universal and stable.
--- Supported EMMC and NOR phones
---- NAND phones support will be added in incoming updates.
4. Added possibility to select custom backup directory.
5. Added custom loader for wiko sunny 3 in custom folder.
This loader can be used to remove phone FRP.
To perform sim unlock is recommended to use DIAG Mode.
Official Website:
NCK DONGLE
Download from Support Access Software to Access Download Area
Link:
http://nckdongle.com/DownloadSetup/s...access_New.rar
The Following 98 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 02-01-2019, 16:46   #2 (permalink)
Member: 364299
Thanks Meter: 41
it this update suport wiko sunny 3 for direct unlock?
The Following User Says Thank You to estil1980 For This Useful Post:
Old 02-01-2019, 17:15   #3 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 4,983
ACTION: Unlock Phone.
Detecting phone, wait...
Phone must be off.
Connect usb cable without pressing any key.
Using connection mode 1
Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140
Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys
Serial number: LA051843001072
IMEI 1: 3580xxxxxxxxxx
IMEI 2: 3580xxxxxxxxxxx
BT: 44D3AD3487DC
WIFI: 44D3AD34684C
Reading simlock, wait....
[0:0][USER]Simlock Status: LOCKED[1] Simlock Counter:[10/10]
[3]Simlock Type: 0 0
Sim 1 Unlock Code: 88190933
Sim 2 Unlock Code: 88191813
Warning, this is factory key, some opperators can modify factory key.
Saved to: C:\Users\xxxxxxxxxx\Documents\spreadtrum_module\ba ckup\spd_simlock_nvram_backup\358074095xxxxxxxxxxx xx__W_K120SUN_user_8_1_0_OPM2_171019_012_153672442 8_release_keys_LA051843001072\
Writing simlock...
Writing simlock ok
Done.
The Following 22 Users Say Thank You to orbita For This Useful Post:
Old 02-01-2019, 17:15   #4 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 4,983
EXE: NckDongle Spreadtrum Module 0.7
SELECTED: SC9832A_EMMC
ACTION: Erase FRP
Custom loader: Sunny3.loader
Detected: SPRD U2S Diag (COM137)
Sending loader, keep boot key untill loader start.
Loader OK: Spreadtrum Boot Block version 1.1
Changing bautrate OK.
Send Second Loader.
FileSystem: EMMC
Manufacturer: WIKO
Hardware: k120_v1.1.0
Build Id: OPM2.171019.012
Model: Sunny3
Android Release: 8.1.0
Android Version: OPM2.171019.012 release-keys
[wfixnv1][Reading]Wrong responce or partition not active.
Removing frp, wait...
Format OK.
Total Time: 00:00:17
Done.
The Following 18 Users Say Thank You to orbita For This Useful Post:
Old 02-01-2019, 18:21   #5 (permalink)
aymandh4's Avatar
Member: 2529545
Thanks Meter: 48
Nice update ..pls add dump firmware
cpu sc9850k is supported just select sc7731c
SELECTED: SC7731C_EMMC
ACTION: Erase FRP
Custom loader: SP631_V9.0_20180725.loader
Detected: SPRD U2S Diag (COM100)
Send Second Loader.
FileSystem: EMMC
Manufacturer: SPA Condor Electronics
Hardware: sc9850ka_1h10_v1.1.0
Model: Griffe T6
Android Version: SP631_V9.0_20180725
Format OK.
Total Time: 00:00:21
Done.
The Following 7 Users Say Thank You to aymandh4 For This Useful Post:
Old 02-01-2019, 18:40   #6 (permalink)
goudio's Avatar
Member: 2098907
Thanks Meter: 117
try to add spd SC983X android 7.x NETWORK unlock
Old 02-01-2019, 19:22   #7 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,338
need funtion dump all latest cpu not only unlock and repair imei and nvram backup.
Old 02-01-2019, 20:03   #8 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 4,983
You can try in diag mode, with big probability it will work.
If not, need to provide nvram backup.
The Following 5 Users Say Thank You to orbita For This Useful Post:
Old 02-01-2019, 22:09   #9 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 120
tested wiko Sunny 3 with old ver
Wiko Sunny 3 Frp Done
The Following User Says Thank You to apologized For This Useful Post:
Old 02-01-2019, 22:44   #10 (permalink)
Member: 1712315
Sonork: 100.1602299
Thanks Meter: 43
PLZ ADD Read PAC File cpu 7731e 8.1.0
Old 02-01-2019, 22:46   #11 (permalink)
Yong Vannak's Avatar
Member: 770210
Thanks Meter: 43
good update please add support Samsung & LG from USA please
Old 02-02-2019, 01:40   #12 (permalink)
Member: 1844172
Sonork: 100.1620999
Thanks Meter: 37
Starmobile play click lte frp
ACTION: Erase FRP
Detected: SPRD U2S Diag (COM10)
[0]Changing Baud Error.
Done.
Old 02-02-2019, 04:58   #13 (permalink)
Member: 2346573
Thanks Meter: 6
Good update fast unlocking team
Old 02-02-2019, 05:30   #14 (permalink)
Member: 90307
Thanks Meter: 13
where can i download it i go to support access but not found
Old 02-02-2019, 06:16   #15 (permalink)
saydajan's Avatar
Member: 1318893
Sonork: 100.1640487
Thanks Meter: 258
every upddate is good, hope to add oppo new models.
Page generated in 0.38945 seconds with 8 queries
