03-19-2019, 18:04 | #32 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Most posible this is not factory firmware. And phone accept only factory firmware. |
The Following User Says Thank You to orbita For This Useful Post: |
03-20-2019, 10:11 | #34 (permalink) |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | oppo a37t boot fail Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKDongle AndroidMTK 2.5.9.8 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port_V1632 (COM7) Boot mode: Brom Phone detected...Please wait BBCHIP: 6755 1 cb00 Using Algo 3. Helio MT6755 phone detected, swithing to helio api Connection mode:BROM No flash definitionj loaded. Please load scatter and preloader for this phone. After repeat opperation again. Error[0xffffffff]: ?? BBCHIP MT6755 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to sajidi1984 For This Useful Post: |
03-20-2019, 10:58 | #37 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Please load scatter and preloader for this phone. After repeat opperation again. | |
03-21-2019, 15:13 | #39 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | MTK have 2 type of phones. Secured and generic. In case of secured phone, need to write only factory firmware, readed from other phone firmware will not be accepted. In case of generic phone, you can read-write phone firmware, not exists any restrictions. This is not related to infinix x624b HOT 7 only, all mtk phones have this rule. Also, this can happen if phone have damaged emmc(read only state). If you 100% sure about factory signed firmware try to exclude from writing secro and simlock and check what will happen. |
03-30-2019, 20:44 | #43 (permalink) |
Insane Poster Join Date: Feb 2016 Location: Honduras Age: 28
Member: 2529300 Status: Offline Thanks Meter: 37 | Please add support for LG-X230F MTK MTK boot sequence: VOL+ & VOL- while connecting USB cable and MTK Preloader Boots or BROM happens I´ve attached images with device booted in MTK boot, however not custom loader was found for it so, cannot do operations. Read Database Log: Code: Exe version: NCKDongle AndroidMTK 2.5.9.8 Selected phone: ELBRUS Action: Backup Modem Database Meta Mode Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [17]Detected: MediaTek USB Port (COM17) \\?\usb#vid_0e8d&pid_0003#5&254a8f52&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [18]META Port Detected: MediaTek USB VCOM (Android) (COM18) USB\VID_0E8D&PID_2006&MI_02\6&33D2373A&0&0002 Start sync target, waiting responce..... ChipID: MT6737M,S01 Using Algo 2. Brand: LG Electronics Board: unknown Model: LG-X230 Name: mlv1_global_com_nr Release: LGX230FAT-00-V10b-TGO-XXX-JUN-19-2017+0 Version: 6.0 Platform: MT6737M [3]Read database error: 0 [0]All done. |
03-31-2019, 07:22 | #45 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 626321 Status: Offline Thanks Meter: 55 | Quote:
why not version NCKBOX AndroidMTK 2.5.9.8??? | |
