12-23-2012, 04:56 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | NCK Dongle v9.5 Bug Fix Released 23/12/2012 Docomo SO-01B Direct Unlock. E10i Direct Unlock. E15i Direct Unlock. E16 Direct Unlock. E16i Direct Unlock. LT18i Direct Unlock. MK16a Direct Unlock. MT11i Direct Unlock. MT15i Direct Unlock. SK17i Direct Unlock. R800 Direct Unlock. SO-01C Direct Unlock. SO-02C Direct Unlock. SO-03C Direct Unlock. ST15i Direct Unlock. ST17i Direct Unlock. ST18i Direct Unlock. U20 Direct Unlock. X8 Direct Unlock. X10 Direct Unlock. X10 Mini Direct Unlock. X10 Mini Pro Direct Unlock. Xperia Active Direct Unlock. Xperia Arco Direct Unlock. Xperia Arc Direct Unlock. Xperia Arc S Direct Unlock. Xperia W8 Direct Unlock. Xperia X10i Direct Unlock. Xperia X10a Direct Unlock. Xperia Mini Direct Unlock. Xperia Mini Pro Direct Unlock. Xperia Pro Direct Unlock. Xperia Play Direct Unlock. Xperia Ray Direct Unlock. HOW TO USE FOR MODELS WITHOUT TP: MAKE SURE NO SIMCARD INSTERTED Code: Before unlocking go to menu, settings, applications->development then set the USB Debugging to ON (tip it) 1. Press Unlock. 2. Phone Must be power off, and press the back key then connect cable (install drivers if needed when prompt) if still not detected remove battery quick and put back while pressing back key. 3. after loader will be sent, software will prompt to remove cable and turn on phone then put cable back, here you must 1. Remove cable, 2. Turn on Phone, wait for anitmated logo then insert cable again. 4. Phone will detect again, then install drivers again if needed (ADB Drivers), then Phone will aut restart again once it restarted software will propmt Press ok when phone start ( wait until phone fully started) then Press ok. 5. wait few seconds and see Phone Unlocked MSG. Happy Unlocking MAKE SURE NO SIMCARD INSTERTED Code: Press Unlock De attach USB CABLE from phone Remove battery from phone Attach TEST POINT Then attach USB CABLE to phone Wait for unlock to start. Follow instruction on screen. PS. Please note that this solution is like all others in market and supports version up to 12w13 Sony Ericsson X8 Unlock OK Code: PROT_VER="02" DATE="20100615" TIME="17:28:00" VER="R4A045" CXC="1229-3641" TYPE="S1_LOADER" UNIQUE_DEV_ID="A70DC035D441C4FAD9D3D3073890D594A3539793" SEC_LOCK_STATUS="LOCKED" OTP_DATA="4DFD7700470404000F080420F94F3C3B" IMEI="01256000286866" AID_VERSION="0004" EROM_AID="0001" LOADER_AID="0001" SW_AID="0001" CUST_AID="0001" SIM_LOCK_AID="0001" HWCONF_AID="0001" PROD_AID="0000" ACTIVE_LOADER_AID="0001" MAN_ID="0020" DEV_ID="00BC" SIN_VER="0001" AID_TAMP="NOT_TAMPERED" MAX_PKT_SZ="00010000" AUTH_LEVEL="NONE" AUTH_MET="0001" CARD_PRESENT="NO" LOADER_ROOT="S1_Loader_Root_8e35" EROM_ROOT="S1_EROM_Root_f54f" SW_ROOT="S1_SW_Root_3edc" CUST_ROOT="S1_Cust_Root_732f" SIM_LOCK_ROOT="S1_SL_Root_a640" HW_CONF_ROOT="S1_HWConf_Root_4b8c" - SE UNLOCK STARTED. - WAITING USER ACTION Device removed from usb usb Device connected to usb - WAITING PHONE - PHONE FOUND - COMMUNICATING WITH THE PHONE Device removed from usb usb Device connected to usb - APPLYING CHANGES Device removed from usb usb Device connected to usb Device removed from usb usb Device connected to usb - WAITING PHONE Device removed from usb usb Device connected to usb - CHANGES APPLIED - VERIFYING CHANGES Device removed from usb usb - STATUS: - UNLOCKED!! Connect server setting true. Device connected to usb Also Official Public Download Link: https://hotfile.com/dl/185761611/1ad...ugfix.exe.html Full News & Updates: http://forum.gsmhosting.com/vbb/f691...dates-1316560/ PS Anyone we find posting 1 free check WE WILL BLOCK DONGLE FOR EVER WITHOUT ANY WARNING. BR NCK Dongle Team |
The Following 16 Users Say Thank You to Fast Unlocking For This Useful Post: |
12-23-2012, 07:40 | #2 (permalink) | |
Product Manager Join Date: Jan 2009 Location: Philippines Pure Pinoy Age: 37
Member: 943187 Status: Offline Thanks Meter: 584 | error x10a unlocking. Quote:
The Following 6 Users Say Thank You to dArk_shAdE For This Useful Post: |
12-23-2012, 10:03 | #3 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | - NO ACCESS, BAD ATTEMPT Device removed from usb usb - STATUS: Device connected to usb Device removed from usb usb Device connected to usb check you final steps made , make sure you run in correct in adb and make you installer correct se adb drivers. after you see "GETTING ROOT ACCESS" DO NOT TOUCH PHONE until procedure complete. DO NOT DETACH PHONE FROM CABLE AFTER PROCEDURE STARTED. DO NOT REMOVE BATTERY FROM PHONE AFTER PROCEDURE STARTED. solutions are: 1. disable antivirus. 2. run as admin. 3. do NOT run exe from read-only media. it can happen that ADB server will not recognize phone after reboot, if phone not detecting automatically and on status bar you can see "waiting phone", again - only in that case - disconnect phone from usb and connect it again, procedure should continue. if not, well, repeat from start. br Last edited by Fast Unlocking; 12-23-2012 at 10:18. |
The Following 3 Users Say Thank You to Fast Unlocking For This Useful Post: |
12-23-2012, 11:09 | #4 (permalink) |
Junior Member Join Date: Sep 2007
Member: 583314 Status: Offline Thanks Meter: 3 | fixed u20 unlock ok @fast unlocking Hi and thank you for the bugfix it worked perfect for the U20 you replied too yesterday. Does the unlock work for the WT19 Walkman as its listed but when i connect it says all done within about 2 seconds. Also how do i check the version like 12w23 as i have looked in the about phone in settings. Thanks in advance. Phoneworx |
12-23-2012, 11:56 | #5 (permalink) | |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | Quote:
Regards WT19 is not supported. BR | |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
12-23-2012, 12:28 | #6 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | Thanks Team Thanks Team Bug Fix Released Quick Service For Ur Friends N customer U No Y I M Best Friend 4 Nck Team Because Nck takes care of there friends And All customer |
12-23-2012, 12:35 | #8 (permalink) |
No Life Poster Join Date: Aug 2007 Location: .::_MaRoC_::.
Member: 567616 Status: Offline Thanks Meter: 157 | - Unlock procedure started, waiting for phone. Device removed from usb usb Device connected to usb - LOADING BOOT, RELEASE TEST POINT - PORT ERROR LT18i B.R Dr.DeathX |
12-23-2012, 12:41 | #9 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | First what is you phones version ? 12w13 and less? and what s your android version? (look at label under the battery). If your phone was produced later than 12W13 (12W16, 12W18, ...) then such new phones are not supported by no one tool. BR Last edited by Fast Unlocking; 12-23-2012 at 12:57. |
12-23-2012, 13:25 | #11 (permalink) | |
reason: SE has changed QCOMM Chip to new secured chip that no at the moment support, we are working on new qcomm secured chips for Sony mobiles, until then nothing can be done and no other team support this also. BR | |
12-23-2012, 16:01 | #14 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | ok seems forgot to add auto save log thanks guys for report, more features will be added in SE after new year. BR |
