08-12-2013, 16:42 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2007
Member: 488833 Status: Offline Thanks Meter: 52 | OT-875 Wrong Codes [ANSWERED] IMEI checksum seems ok Model: OT-875 IMEI: 013337000477118 PID: TBUS1 CODE TYPE 1 (if not work try TYPE 2) NCK=0315664692 NSCK=1908629160 SPCK=3549093212 SIM=0137229229 CORPORATE=0202970561 CODE TYPE 2 NCK=2165404172 NSCK=3220023796 SPCK=3595238550 SIM=2565464445 CORPORATE=2805571930 Log saved to: logs\OT-875_TBUS1_013337000477118.txt |
08-12-2013, 18:03 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Problem with this phone is not wrong codes, firmware is locked and not allow code entering. You can try by other tool and will see same result. Solution is direct unlock here, but for this need to have phone in hands. We search for this phone, if you want to sell one, contact by pm me or fastunlocking please. Can you try make boot info by rj45 cable selecting 871 and 655 models please? Cable is gw300 lg used. Need by rj45 not by usb. |
08-12-2013, 19:04 | #5 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,214 | Solution is direct unlock here, but for this need to have phone in hands. Run NCK Dongle Generic MTK Flash tool , Select OT871 from list then press Make boot info by rj45 cable selecting 871 and 655 models please? Cable used is gw300 lg . Need by rj45 not by usb. |
08-12-2013, 19:08 | #7 (permalink) |
Member: 488833 Status: Offline Thanks Meter: 52 | DA version: 5.1224.04.89 Press and keep power on ... Com port opened...Press power on FlashTool error :S_SECURITY_SEND_AUTH_FAIL(6032) CLOSING COM PORT HANDLE... ALL DONE. |
08-12-2013, 19:23 | #10 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | 3040 try please also. Can you contact me directly? In this phone differ rsa bypass from other phones., and need see exactly about. |
08-12-2013, 19:42 | #12 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Will prepare in some hours test exe to see exactly. Will need some help from you. 1.Format phone(auto fat format) with phone powered off , select usb_cable and when exe ask to insert cable press * and insert cable(if ask for drivers , install it). 2.Without powering phone after format click backup calibration. In backup directory will be folder with com port name. Arhive this folder and post here please. After try also to enter generated codes, posible to be blocked counter and alcatel usually also give wrong code if have blocked counter. btw, phone ask for network code? some phones have also nsck or spck codes. Last edited by orbita; 08-12-2013 at 19:51. |
08-12-2013, 19:56 | #14 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | driver exist in support for this phone or can be in exe directory. All mtk phones use same driver MTK_USB_Driver.rar see in support. |
