07-08-2014, 17:59 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Setif
Member: 1020097 Status: Offline Sonork: 100.1612690 Thanks Meter: 83 | [Ot 908] Sending data failed!!. [ANSWERED] Code: Start Detect device. Port : Qualcomm HS-USB Android DIAG 9018 (COM391) Device detected ok... Preparing to send loader,please wait.. Port : Qualcomm HS-USB Android DIAG 9018 (COM391) Version :76XXT-60501005-TSNCJ Sending loader,please wait.. DL Port detected. Port : Qualcomm HS-USB Android DIAG 9018 (COM391) DL device : Qualcomm HS-USB Android DIAG 9018 (COM391) Loader started ok, reading data... Version : (COM391) IMEI : 000034F6D6D616E Code: Detecting device!! Port : Qualcomm HS-USB Android DIAG 9018 (COM391) IMEI : 3561310413 BT : 94:71:AC:51:15:8A Step 1 done. Start Detect device. Port : Qualcomm HS-USB Android DIAG 9018 (COM391) Device detected ok... Preparing to send loader,please wait.. Port : Qualcomm HS-USB Android DIAG 9018 (COM391) Version :76XXT-60501005-TSNCJ Sending loader,please wait.. DL Port detected. Port : Qualcomm HS-USB Android DIAG 9018 (COM391) DL device : Qualcomm HS-USB Android DIAG 9018 (COM391) Loader started ok, reading data... Version : àÃP IMEI : 000034F6D6D616E Sending : data size : 464 bytes Sending data failed!!. |
07-08-2014, 18:12 | #2 (permalink) |
Member: 1020097 Status: Offline Sonork: 100.1612690 Thanks Meter: 83 | Flach Code: Start Detect device. Port : Qualcomm HS-USB Diagnostics 9017 (COM394) Device detected ok... Preparing to send loader,please wait.. Port : Qualcomm HS-USB Diagnostics 9017 (COM394) Version :76XXT-60501005-TSNCJ Sending loader,please wait.. DL Port detected. Port : Qualcomm HS-USB Diagnostics 9017 (COM394) DL device : Qualcomm HS-USB Diagnostics 9017 (COM394) Loader started ok, reading data... Error request parameter!! IMEI : 000034F6D6D616E Sending : PARTITION size : 464 bytes Sending partition table failed!!. |
07-08-2014, 20:48 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Hi ghano, please be sure you started exe as admin and you not have some antivirus what block exe. |
The Following User Says Thank You to orbita For This Useful Post: |
07-08-2014, 22:05 | #5 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | Quote:
When you start in admin mode it will give this at start of software yes. now try again to flash. also make sure that NCK Box Software is installed in C:\ not program files or other because you might get issues,, if you do this and not work. Contact orbita in yahoo or sonork | |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
07-09-2014, 17:39 | #6 (permalink) |
Member: 1020097 Status: Offline Sonork: 100.1612690 Thanks Meter: 83 | still same problem after flash and hard reset Start Detect device. Port : Qualcomm HS-USB Diagnostics 9017 (COM394) Device detected ok... Preparing to send loader,please wait.. Port : Qualcomm HS-USB Diagnostics 9017 (COM394) DL Port detected. Port : Qualcomm HS-USB Diagnostics 9017 (COM394) DL device : Qualcomm HS-USB Diagnostics 9017 (COM394) Loader started ok, reading data... Version : MOVEX-2BTBHU IMEI : 356131041397269 Sending : PARTITION size : 464 bytes Sending partition table ok. Sending image : QCSBL_HD size : 11,39 KB Sending image : QCSBL size : 56,23 KB Sending header : OEMSBL_HD size : 40 bytes Sending image : OEMSBL size : 483,61 KB Sending header : APPSBL_HD size : 40 bytes Sending image : APPSBL size : 92,07 KB Sending header : AMSS_HD size : 40 bytes Sending image : AMSS size : 16,89 MB Sending image : SECURITY size : 1,05 KB Sending image : BOOT size : 3,28 MB Sending image : SYSTEM size : 69,67 MB Sending image : USERDATA size : 2,06 KB Sending image : CUSTPACK size : 84,06 MB Sending image : RECOVERY size : 3,5 MB Sending image : StudyPara size : 137,55 KB 1ll done.. Detecting device!! Port : ALCATEL HS-USB Android DIAG 9018 (COM51) IMEI : 356131041397269 BT : 94:71:AC:51:15:8A Step 1 done. Start Detect device. Port : ALCATEL HS-USB Android DIAG 9018 (COM51) Device detected ok... Preparing to send loader,please wait.. Port : ALCATEL HS-USB Android DIAG 9018 (COM51) Version :76XXT-60501005-TSNCJ Sending loader,please wait.. DL Port detected. Port : ALCATEL HS-USB Android DIAG 9018 (COM51) DL device : ALCATEL HS-USB Android DIAG 9018 (COM51) Loader started ok, reading data... Error !!24576 Version : (COM394) IMEI : 000034F6D6D616E Sending : data size : 464 bytes Sending data failed!!. |
07-09-2014, 17:42 | #7 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | contact other tool supporters what broke your phone because only they know what they modify in their unlock solution they must provide you a fix. We try with you but seems many is damaged there. |
