02-28-2014, 11:09 | #1727 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | OT-5035D unlock done IMEI checksum seems ok Brand: Alcatel android Model: OT-5035D IMEI :866665010940800 Connecting to server please wait... PID S7RS1 SET (1) NCK: 19444140 NSCK: 02113023 SPCK: 01744407 CPCK: 01675929 CCK: 20380633 Calculated by NCKServer. With non accepted simcard , insert code Alternative metod: Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK New firmware version can generate wrong code, use cable unlock!!!! -------------------------- |
The Following User Says Thank You to zvrrr For This Useful Post: |
03-02-2014, 11:27 | #1728 (permalink) |
Freak Poster Join Date: Dec 2008 Location: india jodhpur
Member: 922365 Status: Offline Thanks Meter: 32 | Module Ver. : 1.3 Com Port : COM3 Baud Rate : 9600 (Auto) Device : Samsung B229 FD09 Operation : Unlock Port opened. Setting test mode... Executing unlock... Resetting phone... Phone must restart if everything OK! Operation finished. Port closed. Elapsed Time: 00:05 |
The Following User Says Thank You to MR KHATRI For This Useful Post: |
03-02-2014, 13:07 | #1729 (permalink) |
No Life Poster Join Date: May 2012 Location: NCK Team
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | Alcatel OT-995 unlock done via code calc Code: IMEI checksum seems ok Brand: Alcatel android Model: OT-995 IMEI :8693980******** Connecting to server please wait... PID TBHU1 SET (1) NCK: 2530815828 NSCK: 4089480087 SPCK: 0953978391 CPCK: 1565712597 CCK: 0572945163 PID TBHU1 SET (2) NCK: 2304051694 NSCK: 2357591559 SPCK: 1238500475 CPCK: 1986631652 CCK: 3829824065 Calculated by NCKServer. New firmware version can generate wrong code, use cable unlock!!!! -------------------------- Log saved to: logs\8693980********_OT-9951.txt All done |
03-02-2014, 17:58 | #1730 (permalink) |
Freak Poster Join Date: Nov 2009 Location: INDIA
Member: 1156346 Status: Offline Sonork: 100.1606988 Thanks Meter: 38 | Zte S160 new version unlock sucess Zte s160 new version unlock sucess by cross flashing Code: Module Ver. : 1.3 Com Port : COM52 Baud Rate : 115200 Device : ZTE S160 Operation : Flash Port opened. Compile : Dec 17 2010 16:49:34 Release : Apr 24 2009 24:00:00 Hw Ver. : RIC_S160 ESN : 809D891F MEID : A000002B61050F MemUnlock : Success Build : RIC_S160_RBTL21NV1.0.0B08 Detected : S160 User Code : 0000 Setting Download mode... Mode change OK. Waiting for phone... Reconnect OK. Initializing Flash Protocol... Flash Chip : INTEL 128 L18 ADMuxd Chip Size : 16 MB Flash File : zte c1602 unlocked dump.bin File Size : 0x01000000 Writing flash... Write flash finished. Resetting phone... Operation finished |
The Following 2 Users Say Thank You to vanand For This Useful Post: |
03-03-2014, 15:04 | #1731 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | vodafone v875 (alcatel ) read codes other failed nck rockes Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM22) Phone detected...Please wait Sending DA agent, please wait... OTP IMEI : 3xxxxxxxxxxxxxx MODEL FW: V875-2AVDNZ2˙ Reading security, wait... SECRO FW : XHI0CR00 NCK : 05477319 NSCK : 17947605 SPCK : 01315788 SPCK : 33161004 Simlock saved to : C:\NCK Dongle\NCK Dongle Android MTK Flash Tool Module\simlock_backup\XHI0CR00_backup.nsb All done. |
The Following User Says Thank You to luckymobile jalandhar For This Useful Post: |
03-04-2014, 04:40 | #1732 (permalink) |
No Life Poster Join Date: Nov 2010 Location: THE MOBILE SHOP
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.3 Com Port : COM2 Baud Rate : 115200 Device : Alcatel C131 Operation : Unlock Port Opened. Reading Information... Compile : Jun 25 2013 13:12:50 Release : Apr 29 2011 05:00:00 Hw Ver. : V.MTS.C1 ESN : 80C1FB56 MEID : A100003BB08E4C Build : V.MTS.C131.B04 User Code : 0000 Setting Download Mode... Download Mode OK, Reconnecting... Reconnection OK Sending Bootloader... Initializing Flash Chip... Flash Chip : INTEL M36W0R6050d Chip Size : 8 MB Patching Firmware... Restarting Phone.. Phone successfully unlocked. Port Closed Operation failed! Elapsed Time: 00:15 |
The Following User Says Thank You to sunilkumar70791 For This Useful Post: |
03-04-2014, 08:12 | #1733 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1967220 Status: Offline Thanks Meter: 14 | Megafon U8180 (Huawei U8180) - Unlocked Code: Now connect phone to PC Start detect phone. Injecting Loader.. Reconnecting phone, this can take few second.. Start detect phone. Loader started ok. Reading Phone Info, please wait.. Phone Imei : 357232******** Phone SN : D5J4CD11C0611377 Phone Firmware : U8180-1V100R001C00B620_E SimLock marker found.. Total markers found : 1 Simlock Status : Locked. Removing SimLocks Please Wait... Read marker : 1 Write marker : 1 All Done. If Phone not have network after unlock, use fix network please. |
The Following User Says Thank You to Donie951 For This Useful Post: |
03-05-2014, 13:16 | #1738 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Alcatel ot-918 with counter blocked successfully unlocked by direct unlock method... Code: Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Phone imei : 8607670029xxxx Simlock Info : Sim(1) Block1(N ):Locked (remain:0) Code : 39213709 Block2(NS):Unlocked Code: 32338401 Block3(SP):Unlocked Code: 41102577 Block4(C ):Unlocked Code: 41562353 Block5(SIM):Unlocked Code: 05986304 Start direct unlock... 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 ------------------------------------ 55002560031300000E3B00005E02860002001000000088F001000E000F001900D60001000000F2F24B All done. |
The Following User Says Thank You to sebY7676 For This Useful Post: |
03-05-2014, 13:27 | #1739 (permalink) |
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.3 Com Port : COM174 Baud Rate : 115200 Device : Lava L661 Operation : Unlock Opening Port... Reading Information... Compile : Jul 25 2013 10:42:15 Release : Apr 29 2011 05:00:00 Hw Ver. : SBNAAHZ3 ESN : 80D10D4F MEID : A100000CD02788 Build : Q1110-SBNAAHZ-3390 User Code : 0000 Setting Download Mode... Waiting for Phone... Connected to Phone. Preparing Phone... Sending Loader... Initializing Protcol... Flash Chip : SPANSION S71VS128RB0d Chip Size : 16 MB Patching EFS Zone... EFS Zone Patched Successfully! Restarting Phone... Phone Successfully Unlocked. Port Closed. Operation Finished. Elapsed Time: 02:38 |
03-06-2014, 18:25 | #1740 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | I am also done Virgin Mobile VM575 unlock done by nck box Quote:
I am also done Virgin Mobile VM575 unlock done by nck box I used this Driver This Drivers Support All Spreadtrum It working in windows 7 (aslo Windows 64 bit) It is Last Driver for Spreadtrum Download | |
The Following User Says Thank You to razib143 For This Useful Post: |
