12-15-2015, 08:58 | #4156 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Download DA now...You can release power on Reading model info, wait...... CBR RECORD EXIST. MODEL FROM CBR: 2012G-2AVDGB1 SECRO FROM CBR: X5D75EE2AS00 Reading imei info, wait...... HARDWARE IMEI: 865360027023508 Backup saved to: C:\NCK Dongle\GenericMTK\alcapid_backup\OT-2012G\865360027023508_2012G-2AVDGB1_X5D75EE2AS00_secro_backup_12-15-2015-14-40-19.bin Getting phone info .... BaseBand CPU: MT6260_S0000 FLASH TYPE: NOR ID: NOR128Mb+128Mb) [MXIC] MX25U12835FZNI_10G size: 0x01000000 INT RAM: 416Kb RAM: 128Mb SRAM BOOT STYLE: S_SF_FLASH_BOOT(1031) Phone Succussfully Unlocked. Disconnecting phone :S_DONE(0) ALL DONE. |
12-15-2015, 12:04 | #4157 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Huawei Y511-U251 flashing success Code: Flash files count is :11 Action : Firmware update. Selected Huawei: Ascend Y511-U251 Exe version: NCKDongle AndroidMTK 2.5.6.1 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM3) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A4834473164 : 0000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
12-15-2015, 12:27 | #4158 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | j110h read unlock code done Code: PHONE SELECTED: SM-J100H Port: SAMSUNG Mobile USB Modem #33(COM200) Phone Detected. SM-J110H Model: SM-J110H Base: SM-N900 Version: J110HXXU0AOGA/J110HOJV0AOGB/J110HXXU0AOGA/J110HXXU0AOGA PRD: SM-J110HZWDKSA SN: R51GB10NXDL IMEI: 3552540785------ SIMLOCK:LOCKED[Phone May Be Hard Locked] Unlocking, wait. Reading locks, wait. Resetting Lock Codes... Done UnFreeze: 00712621 Net Lock: 83626762 For check lock use: *#7465625# -------------------------- Log saved to: logs\SM-J100H__unlock__3.txt Done. |
The Following User Says Thank You to rehmani For This Useful Post: |
12-15-2015, 14:27 | #4159 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte s183 repair security and unlock done repair security Code: Module Ver. : 3.1 Com Port : COM89 : ZTE CDMA Handset Diagnostics Interface (COM89) Baud Rate : 921600 Device : C132 Operation : Write MEID Port opened. Compile : Jun 14 2013 10:06:37 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.C1 ESN : 00000000 MEID : 00000000000000 MemUnlock : Success. Build : V.MTS.C132.B04 Detected : C132 User Code : 0000 Writing MEID A00000384----- Write success. New ESN : 80E8---- New MEID : A00000384----- Operation finished. Port closed. Elapsed Time: 00:01 Code: Com Port : COM89 : ZTE CDMA Handset Diagnostics Interface (COM89) Baud Rate : 921600 Device : ZTE C132 Operation : SP UNLOCK Port opened. Compile : Jun 14 2013 10:06:37 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.C1 ESN : 80E88--- MEID : A0000038------ MemUnlock : Success Build : V.MTS.C132.B04 Detected : C132 User Code : 0000 Setting Download mode... Mode change OK. Waiting for reconnect... Initializing Flash Protocol... Flash Chip : SPANSION S71VS064RB0d Chip Size : 8 MB Patching security area... Patching success. Resetting phone... Phone successfully unlocked. Port closed. Operation finished. Elapsed Time: 00:14 Log saved as \!Log\LOG_15_12_15_18_34_15.log |
12-15-2015, 18:42 | #4160 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel 7040N Direct Unlock done.. Phone must be ON. USB Drivers must be installed and diagnostic port must be enabled. Port: ALCATEL HS-USB Diagnostics 9017 (COM115) Build id : MPSS.TR.2.0.c13-00017-M8610BAAAANAZM-1 Version info : Dec 12 201413:49:42Nov 26 201401:00:00BAAAANAZ: ÿd IMEI : 014316003203886 Start reading.. Simlock Status: SIMLOCK[0] Lock SIMLOCK[1] Unlocked SIMLOCK[2] Unlocked SIMLOCK[3] Unlocked SIMLOCK[4] Unlocked Start direct unlock, wait.... Direct unlock done. Please restart phone. Backup saved to : C:\Users\Dell_Laptop\Documents\NckBox\backup\alcat el_android\OT-7040N_014316003203886_simlock_backup_1.bin |
12-16-2015, 03:09 | #4161 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | Bmobile AX690 code calculation ... Quote:
12-17-2015, 04:25 | #4163 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V7 locked To Beeline UZ direct unlock done ... Quote:
12-17-2015, 04:26 | #4164 (permalink) | |
12-17-2015, 04:27 | #4165 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | Micromax Bolt D303 locked to Megafon Direct unlock done ... Quote:
12-17-2015, 09:11 | #4166 (permalink) | |
Insane Poster Join Date: Aug 2011 Location: Gsm FuriouS TeaM -_- Z3X
Member: 1627125 Status: Offline Sonork: 100.1652422 Thanks Meter: 21 | ((Blu Model Studio S070Q FRP RESET Done! By NCK Box)) Blu Model Studio S070Q FRP RESET Done! By NCK Box Quote:
Greetings! djstich | |
12-17-2015, 14:04 | #4167 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Vodafone Smart First 6 Direct Unlock done.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.3 Selected phone: Vodafone Smart First 6 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) MICRON 0x50314a39344d EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A3934 : 0000000000000000 EMMC UA SIZE: 0xe9800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9b00000 [3.651 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Block Size: 512 MODEL FROM PROINFO: V695-2AVDGB2 SECRO FROM PROINFO: X8I0HE01AZ10 IMEI marker was found in nvram OTP ADRESS: 0xffff0200 OTP IMEI[1]: 357773066738973 Reading security, wait... SIM[1]: Block1(N): Locked (remain:4) Code : 38891268 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
12-17-2015, 14:22 | #4168 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | TECNO Y4 Privacy Lock reset done.. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x4b3758564d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004B3758564D : 0000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Dumping data, wait. Value found, procesing[010c][00460000] Resetting phone. FORMAT EMMC FLASH : BEGIN: 0x76500000 - LEN: 0x15ae80000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. All done. |
12-18-2015, 17:23 | #4170 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V7 locked to Beeline Uz Unlock done..... Quote:
