09-21-2017, 06:06 | #5821 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | Panasonic P55 eluga flash done Action : Firmware update. Selected Model: 0-By CPU: MT6571_EMMC Exe version: NCKDongle AndroidMTK 2.5.7.9 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM3) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (56Gb+8192Mb) KSI 0x563130303038 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 70010056313030 : 000000000000000000 EMMC UA SIZE: 0x1c3000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1c3c00000 [7.059 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM12) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
The Following User Says Thank You to ssony For This Useful Post: |
09-21-2017, 14:41 | #5824 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | ALcatel OT 4017X unlock done Code: Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.8.0 Selected model: OT-4017X Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM9) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) TOSIBA 0x303034474530 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 11010030303447 : 000000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec480000 [3.692 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM12) MODEL FROM PROINFO: 4017X-2CRGTE1 SECRO FROM PROINFO: LBL1E1S4AZ10 OTP IMEI: 356388071095086 Reading security, wait... SIM[1]: Block1(N): Locked (remain:10) Code : 9642612207409321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. [0]Unlock finished. [1]Unlock finished. Wait untill phone will start charging. All done. |
The Following User Says Thank You to gunit1 For This Useful Post: |
09-22-2017, 08:15 | #5825 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | LG L70 D320n remove pattern done :) Port: COM550:=LGE AndroidNet USB Serial Port (COM550) Waiting for Phone Ack... Sending Loader.. Reading Phone Information.. Model : LG-D320n SW Verion : LGD320nAT-00-V10b-OP1-SI-AUG-18-2014+0 Android Verion : 4.4.2 IMEI : 352269060504276 Product ID : CT68S140401002283 H/W Version : rev_10 Removing Selected Screen Lock(s).. OK Enabling Usb Debug... OK Rebooting to Normal Mode... OK All Done.. -------------------------- Log saved to: C:\Users\Zvr\Documents\NckMain\Exe_Logs\lg_MTC-970_reset_pattern_1.txt https://prnt.sc/go81hm |
The Following User Says Thank You to zvrrr For This Useful Post: |
09-22-2017, 13:45 | #5826 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Ireland Age: 50
Member: 2038882 Status: Offline Sonork: 100.1663803 Thanks Meter: 67 | Huawei G7 - 2 pieces unlocked in a minute with NCK Team 017-09-22 13:30:48.377 Autodetect COM port and phone type start! 2017-09-22 13:30:49.270 Found COM port: COM22 2017-09-22 13:30:49.278 Found phone type: Huawei Android phone (Qualcomm CPU) 2017-09-22 13:30:49.296 Connecting to server... 2017-09-22 13:30:50.200 Connected! 2017-09-22 13:30:50.222 Open COM port COM22 (DBAdapter Reserved Interface (COM22))... 2017-09-22 13:30:55.335 Read phone secure info... 2017-09-22 13:30:55.391 Read phone basic info... 2017-09-22 13:30:55.438 Phone info data backup saved to file C:\UMTool\UltimateHwe\20170922_133055_864324026489 277.BAK 2017-09-22 13:30:55.443 Read unlock codes start 2017-09-22 13:30:58.153 Read from server... 2017-09-22 13:31:05.637 Read from server success! 2017-09-22 13:31:05.646 Decrypting codes... 2017-09-22 13:31:05.734 Decrypt security data success! 2017-09-22 13:31:07.384 Read unlock codes done! NCK code = 0837xxxxxxxxxxx NET_SUB code = 5288xxxxxxxxxx SP code = 23527xxxxxxxxx Unblok code = 6400xxxxxxxxxx 2017-09-22 13:35:29.330 Autodetect COM port and phone type start! 2017-09-22 13:35:30.233 Found COM port: COM22 2017-09-22 13:35:30.248 Found phone type: Huawei Android phone (Qualcomm CPU) 2017-09-22 13:35:30.270 Connecting to server... 2017-09-22 13:35:31.824 Connected! 2017-09-22 13:35:31.840 Open COM port COM22 (DBAdapter Reserved Interface (COM22))... 2017-09-22 13:35:37.550 Read phone secure info... 2017-09-22 13:35:37.595 Read phone basic info... 2017-09-22 13:35:37.630 Phone info data backup saved to file C:\UMTool\UltimateHwe\20170922_133537_864324029298 824.BAK 2017-09-22 13:35:37.635 Read unlock codes start 2017-09-22 13:35:40.447 Read from server... 2017-09-22 13:35:50.487 Read from server success! 2017-09-22 13:35:50.495 Decrypting codes... 2017-09-22 13:35:50.683 Decrypt security data success! 2017-09-22 13:35:55.718 Read from server fail! 2017-09-22 13:35:55.738 Read unlock codes done! NCK code = 22422xxxxxxxxx NET_SUB code = 79203xxxxxxxx SP code = 13908xxxxxxxxxxxxx Unblok code = 6190xxxxxxxxxxxxx Thanks NCK Team Best of like every time. |
The Following User Says Thank You to xchanges For This Useful Post: |
09-22-2017, 17:39 | #5827 (permalink) |
No Life Poster Join Date: Aug 2007 Location: jinja,uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 249 | Pattern reading done Exe version: NCKBox AndroidMTK 1.8.8.1 Selected model: MT6572_EMMC Action: Read Pattern Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM450) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x4b3758564d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004B375856 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 ************************************** 1 2 3 4 5 6 7 8 9 Pattern: 14569 ************************************** HEX: AF4E03A1C266DE9458035280DDA1B69D2D7825DE ************************************** Wait untill phone will start charging. All done. |
09-23-2017, 07:04 | #5828 (permalink) |
Insane Poster Join Date: Oct 2011 Location: Karnataka.bangalore
Member: 1681098 Status: Offline Sonork: mahindra Thanks Meter: 74 | vivo y21l vivo y21l pattern lock done with nck REMOVED for posting serial in public, next time post without showing card serial to avoid blocking your card |
09-23-2017, 11:21 | #5830 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Motorola XT1771 MT6737 read full flash done Code: Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM13) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 2. ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (116Gb+24576Mb) SAMSUNG 0x524531424d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 15010052453142 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM40) Build ID: NMA26.42-11-3 Version: 7.1.1 Build Date: Sat May 6 04:42:45 CDT 2017 Model: Moto E (4) Plus Brand: motorola Device: nicklaus Manufacturer: motorola Mediatek Version Release: alps-mp-n1.mp1-V1_lenovo6737m.35.n1_P42 Dumping Preloader. Start dumping flash, this can take up to 1 hour....... Start procesing proinfo Reading: BEGIN: 0x80000 - LEN: 0x300000 Start procesing nvram IMEI[1] from NVRAM: 355633086520xxx IMEI[2] from NVRAM: 355633086560xxx Start procesing protect1 ...... Reading: BEGIN: 0x880000 - LEN: 0xa00000 Start procesing protect2 ...... Reading: BEGIN: 0x1280000 - LEN: 0xa00000 Start procesing lk ...... Start processing boot Start processing recovery Start procesing logo ...... Start procesing secro Reading: BEGIN: 0x5380000 - LEN: 0x600000 Start procesing trustzone Start procesing persist ...... Reading: BEGIN: 0x6b80000 - LEN: 0x3000000 Start procesing utags ...... Reading: BEGIN: 0x9c00000 - LEN: 0x80000 Start procesing frp ...... Reading: BEGIN: 0x9c80000 - LEN: 0x100000 Start procesing nvdata ...... Reading: BEGIN: 0x9d80000 - LEN: 0x2000000 Start procesing hw ...... Reading: BEGIN: 0xdd80000 - LEN: 0x800000 Start procesing oem ...... Reading: BEGIN: 0xe580000 - LEN: 0x10280000 Start procesing system Reading: BEGIN: 0x1e800000 - LEN: 0xc0000000 Saved to : C:\Documents and Settings\Galijus\My Documents\Android_MTK\firmware_backup\MT6737M_EMMC_motorola_Moto E (4) Plus_7_1_1_alps-mp-n1_mp1-V1_lenovo6737m_35_n1_P42(2017_09_23_12_10) Wait untill phone will start charging. All done. |
09-26-2017, 14:04 | #5831 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.8.1 Selected model: OT-4034X Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM81) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x464a32354142 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 150100464A3235 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM101) MODEL FROM PROINFO: 4034X-2AOBGB2 SECRO FROM PROINFO: X3D0CF02BS10 OTP IMEI: 3542880772AAAAA2 Reading security, wait... SIM[1]: Block1(N): Locked (remain:9) Code : 4146740163238534 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. [0]Unlock finished. [1]Unlock finished. CHK updated ok. Wait untill phone will start charging. All done. |
09-29-2017, 13:39 | #5833 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.8.1 Selected model: OT-9005X Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM98) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051373253 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM99) MODEL FROM PROINFO: 9005X-2BRGGW3-1 SECRO FROM PROINFO: X2B0DA01AU00 OTP IMEI: 356682060AAAA6 Reading security, wait... SIM[1]: Block1(N): Locked (remain:8) Code : 1862342049 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
The Following User Says Thank You to razib143 For This Useful Post: |
09-29-2017, 13:54 | #5834 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | HUAWEI G630-U20 HANG ON LOGO DONE BY FLASHING FIRMWARE WIT NCK Q MODULE Checking firmware UPDATE.APP, wait. Using algo for HW8x12 Port: Android Adapter PCUI (COM320) MD5RSA: $FE000000 SIZE: $ 80 Blocks: $ 0 CRC: $FF000000 SIZE: $12452 Blocks: $ 12 OEMSBL_VERLIST: $E8000000 SIZE: $ 348 Blocks: $ 0 AMSS_VERLIST: $EA000000 SIZE: $ 2BC Blocks: $ 0 GPT: $D2000000 SIZE: $8600 Blocks: $ 8 RPM: $C2000000 SIZE: $23F40 Blocks: $ 23 TZ: $C3000000 SIZE: $52C2C Blocks: $ 52 SBL1: $C6000000 SIZE: $48234 Blocks: $ 48 MODEM: $C1000000 SIZE: $23B6600 Blocks: $23B6 SDI: $C9000000 SIZE: $4910 Blocks: $ 4 OEMSBL_VER: $E9000000 SIZE: $ 1C Blocks: $ 0 AMSS_VER: $EC000000 SIZE: $ 17 Blocks: $ 0 MODEMST1: $EE000000 SIZE: $400000 Blocks: $ 400 MODEMST2: $EF000000 SIZE: $400000 Blocks: $ 400 FSG: $10000000 SIZE: $10F28 Blocks: $ 10 ABOOT: $E3000000 SIZE: $95354 Blocks: $ 95 RECOVERY: $40000000 SIZE: $C1B800 Blocks: $ C1B SYSTEM: $ 0 SIZE: $3B0A74B0 Blocks: $3B0A7 Retry[0] adress: 0x14F0000 Retry[0] adress: 0xB3C7000 Retry[0] adress: 0x2F9DA000 Retry[0] adress: 0x323FC000 USERDATA: $30000000 SIZE: $1270238 Blocks: $1270 CACHE: $50000000 SIZE: $59A0D0 Blocks: $ 59A Retry[0] adress: 0x504F7000 CUST: $70000000 SIZE: $7FC7AD8 Blocks: $7FC7 PERSIST: $C7000000 SIZE: $42E094 Blocks: $ 42E BOOT: $FC000000 SIZE: $AFC000 Blocks: $ AFC After flash phone can start in recovery mode. If this happen, wipe phone[FACTORY RESET]. Done. |
09-30-2017, 02:02 | #5835 (permalink) |
Freak Poster Join Date: Jul 2006 Location: aghbala Age: 40
Member: 312667 Status: Offline Sonork: 1000.2 Thanks Meter: 61 | Successfully UNLOCK OT 5065D Operation: Unlock phone. Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1009600 MSM8909 PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F STORAGE TYPE: EMMC Sending loader, please wait.. Waiting for loader to start... DiskSize: 7,28 GB Userdata Size: 4,53 GB Partitions count: 40 Manufacturer: TCL Cpu: armeabi-v7a Build Id: LMY47V Model: 5065D Android Release: 5.1.1 Android Version: LMY47V release-keys IMEI: 358801060265294 Model: 5065D-2DALMA1 Secro: X2A0H800BR20 Reading: traceability Reading: simlock Reading: tctpersist Saved to: C:\Users\s3\Documents\NckBox\alcatel_simlock_backu p\TCL_LMY47V_5065D_5_1_1_358801060265294_5065D-2DALMA1_X2A0H800BR20\ Step 1 ok. Writing simlock ok. Restarting phone..... |
The Following 2 Users Say Thank You to OUSKHMANE For This Useful Post: |
