12-03-2014, 21:27 | #1 (permalink) |
Insane Poster Join Date: May 2014 Location: CUBA
Member: 2188300 Status: Offline Thanks Meter: 11 | Problem to unlock ot-4015t att [ANSWERED] THE CODES CALCULATED BY NCK CALCULATOR ITS WRONG THEN USIN ANDROID MTK VER 2.5.4.4 THIS THE LOG Phone must be off with battery inside. Please insert USB cable now... Detected : USB Single Port (COM59) Connect error: Fails to open Com port because other application is using this Com port or this application hasn't release Com port correctly. Please check it. All done. HELP ME |
12-03-2014, 21:32 | #2 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,239 | Fails to open Com port change ports or check what s making conflict in pc ports, please don t say nothing making as software simply checks ports to connect with phone so please check all first could be also drivers conflict and What PID is your 4015T |
12-03-2014, 22:37 | #5 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | i'am just checked this model Exist ot-4015t and 4015att, your phone what model is? If posible please post complete phone pid and secro name for this phone. |
12-04-2014, 16:38 | #6 (permalink) |
Member: 2188300 Status: Offline Thanks Meter: 11 | my phone for unlock is alcatel ot-4015t company AT&T country USA the codes calculated for calculator its wrong when reading USIN ANDROID MTK VER 2.5.4.4 THIS THE LOG Phone must be off with battery inside. Please insert USB cable now... Detected : USB Single Port (COM59) Connect error: Fails to open Com port because other application is using this Com port or this application hasn't release Com port correctly. Please check it. All done. |
12-04-2014, 17:12 | #8 (permalink) |
Member: 2188300 Status: Offline Thanks Meter: 11 | mr orbita my english its very bad im sorry for all need help secro name? this mobile inside data model 4015t H/W:05 Imei 013929000765623 S/n QBJE07BOTIXHQJ2 sku: 6252A WHEN MARK *#3228# THIS THE NUMBER B6C80000AN00 Y6C80000AN00 C6C8UA02AN00 P6C80000AN00 U6C80000AN00 R6C80000AN00 THANKS Last edited by hold20100; 12-04-2014 at 17:19. |
12-04-2014, 17:54 | #9 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Can you contact me directy by yahoo meesenger or sonorq with rooted phone? Codes are corect, in support exist 4 secro for this model and pid and all give same code. If codes is wrong for you, most posible here is changed some. |
12-04-2014, 18:02 | #10 (permalink) |
Member: 2188300 Status: Offline Thanks Meter: 11 | MR ORBITA NO HAVE YAHOO OR SONORQ THE PHONE ITS ROOT IN ADB MODE Read Info Start. Phone lcd must be on and unlocked. If ask for SU acces, accept it. Device have root ---BOARD INFO---- Manufacturer: TCT Device: Yaris35_GSM Version: 4.2.2 Board: ALCATEL_4015T Model: ALCATEL 4015T ---PHONE INFO--- TYPE: GSM IMEI : 013929000765623 --CPU INFO-- Processor : ARMv7 Processor rev 3 (v7l) Hardware : MT6572 Revision : aaff ---LOCKS SIM1---- NCK : Locked :Count: 4 Code : 53315628 ........ Network Subset Lock : Unlocked Code : 71992690 ........ SP Lock : Unlocked Code : 16090127 ........ CP Lock : Unlocked Code : 36947917 ........ ---LOCKS SIM2---- NCK : Locked :Count: 10 Code : 53315628 ........ Network Subset Lock : Unlocked Code : 71992690 ........ SP Lock : Unlocked Code : 16090127 ........ CP Lock : Unlocked Code : 36947917 ........ --------- I HAVE 3 4015T TO UNLOCK FOR ALL PHONE THIS THE CODES TO READ AND CODES ITS NO ACCEPT IN FLASH MODE THE ERROR ITS IN 1ST POST |
12-04-2014, 18:19 | #11 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | IMEI checksum seems ok Brand: Alcatel android Model: OT-4015T IMEI :013929000765623 Connecting to server please wait... PID: AQUS1 NCK: 1944644102 NSCK: 2858890797 SPCK: 0261742418 CPCK: 1335836807 CCK: 0321825418 This codes not work for you? Last edited by orbita; 12-04-2014 at 18:25. |
12-04-2014, 18:32 | #14 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,239 | read his answer if you want help do as he ask you if not feel free to find other solution http://forum.gsmhosting.com/vbb/10716091-post4.html this thread is just dragging CLOSED |
