12-30-2017, 20:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | REDMI NOTE 4 not suported? Selected 0-By CPU:MT6795 Exe version: NCKDongle AndroidMTK 2.5.8.3 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6797 BaseBand CPU Secure Version : 00 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 256 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (466Gb+24576Mb) TOSIBA 0x303634473330 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 11010030363447 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe90400000 [58.254 GB] Preloader SEC version: 0 Status: USB_HIGH_SPEED Build ID: MRA58K Display ID: MRA58K Version: 6.0 Build Date: Mon Aug 22 22:45:33 CST 2016 Model: Redmi Note 4 Brand: Xiaomi Device: nikel Mediatek Version Release: alps-mp-m0.mp9-V1.64_lcsh6797.6c.lw.m_P68 OTP IMEI: 8ccccccccc Wait untill phone will start charging. All done. and this is all what I receive from phone and NCK. Any try of dumping, or flashing result with frozen aplication at this point : Flash files count is :21 Action : Firmware update. Selected Model: 0-By CPU: MT6795 Exe version: NCKDongle AndroidMTK 2.5.8.3 Scenario: [1]Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6797 BaseBand CPU Secure Version : 00 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 256 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (466Gb+24576Mb) TOSIBA 0x303634473330 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 11010030363447 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe90400000 [58.254 GB] Preloader SEC version: 0 Status: USB_HIGH_SPEED Flash EMMC Algo Start. |
12-30-2017, 20:39 | #2 (permalink) |
Member: 84300 Status: Offline Thanks Meter: 74 | and after 5 minute ReadbackPartitionToBuffer() failed!(3). Error while dumping Preloader. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x0 - LEN: 0x0 next 3 minute Error: STATUS_FORMAT_EXCEPTION [EMPTY]WARNING ..format adress not detected! [-1073414135]Warning : STATUS_FORMAT_EXCEPTION |
12-30-2017, 20:43 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Just sugestion, phone can have hardware problem also. If phone have hardware problem, this can't be solved by flashinmg firmware. Also, hardware damaged phone can have connection problems. If phone is hardware damaged or have connection problems, this is not exe bug. Exe have reading timeout, yes, trying to get repply from phone. If exe not get repply from phone, it exit with error. This is normal, is not a bug. |
12-30-2017, 20:56 | #4 (permalink) |
Member: 84300 Status: Offline Thanks Meter: 74 | [-1073414143]Error: STATUS_DEVICE_CTRL_EXCEPTION All done. total time 14:02 wished to edit upper mesage, but it's time limited 10 minute Phone was just user locked, and wish to flash new firmware to clean all . After format - wipe data phone stuck on MI logo, charging well . Action : Format UserData. Selected 0-By CPU:MT6795 Exe version: NCKDongle AndroidMTK 2.5.8.3 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6797 BaseBand CPU Secure Version : 00 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 256 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (466Gb+24576Mb) TOSIBA 0x303634473330 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 11010030363447 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe90400000 [58.254 GB] Preloader SEC version: 0 Status: USB_HIGH_SPEED Detecting format adress....wait! Starting generic userdata format...! Partition: cache begin: 0xee800000 length: 0x1b000000 Partition: userdata begin: 0x109800000 length: 0xd824fbe00 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. Wait untill phone will start charging. All done. Last edited by Crumarix1; 12-30-2017 at 21:03. |
12-31-2017, 08:37 | #5 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In modern phones, flashing new firmware many time not help to clean locks. This phone not allow reading from region 1 Code: ReadbackPartitionToBuffer() failed!(3). This not meen as you writed, REDMI NOTE 4 not suported. This meen your specific phone have some locks or some problems or some.... If you have experience with gsm phones and have phone in hands, you must find yourself. Software is maked to do specific tasks, but you must find where is problem and take decision what to do. On topic, try to use reset to factry default or clean emmc function. Some phones usually come with prefiled userdata and can create problem on direct reset. |
01-03-2018, 21:47 | #6 (permalink) |
Member: 84300 Status: Offline Thanks Meter: 74 | OK... solved . 1. flashed with SP flasher only boot & system from CHINESE version 2. after phone alive, flashed complete chinese flash without CUSTOM 3. on MI site asked for bootloader unlock, after fiew days phone unlocked 4. flashed TWRP 5. thrue TWRP flashed GLOBAL version DONE ! |
01-04-2018, 08:29 | #7 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In this phone was not writed nothing by nckdongle, so phone must remain in exactly same state based on your posted logs. And from what you posted after, phone become alive after writing boot.img and system. Is super, you maked your phone alive but at least try to post real story about phone, what you posted is totally nosence. And btw, selecting safe flash and unckecking all other partitions was posible to do same with android mtk. If you decided to use sp flash tool was your decision here. |
